Gluing question
« back to Joinery forum
Forum topic by williamhdixon posted 06-19-2018 03:06 AM 649 views 0 times favorited 11 replies Add to Favorites Watch
View williamhdixon's profile
williamhdixon
9 posts in 400 days
06-19-2018 03:06 AM
I have a newbie question about gluing.
I’m going to be trimming a plywood edge with a 1×2 strip, attached via tongue & groove. (Tongue on the 1×2, groove in the plywood, if it makes a difference.)
I know that plywood is fairly stable as far as expansion/contraction, but the 1×2 is not. So as I understand the concept, if I apply glue down the entire length it can split over time. I recall seeing somewhere that you should not apply glue from one end to the other, but I don’t remember all the details.
So my question is this. If the strip is 24” long, how much of it should I glue and how much of it should I leave bare? Or is there some other technique I should use?
Thank you to anyone who takes the time to answer this.
Bill
11 replies so far
View JBrow's profile
JBrow
1366 posts in 1090 days
#1 posted 06-19-2018 03:33 AM
williamhdixon,
Solid wood expands minimally along it length. Since plywood likewise expands minimally along its width and length, I foresee no problems gluing the entire length of the solid wood edge banding to the plywood edges.
Perhaps you are already planning to ensure the solid wood edge banding is a little thicker than the plywood and, when glued in place, the edge banding is proud of both faces of the plywood. The edge banding is then routed flush to the plywood faces with a flush trim bit. I find this method reduces the chances of damaging the plywood with a card scraper and/or sand paper when flushing-up the surfaces.
Applying glue along the entire length of a joint of a solid wood panel and a trim strip when the grain direction of the two glued pieces is perpendicular could lead to problems. In this case gluing no more than about 3” near the center (along its length) of the joint would be appropriate. But since your panel is plywood, the cross-grain expansion problem associated with a solid wood panel is absent in this case.
View Bobthewoodbutcher's profile
Bobthewoodbutcher
27 posts in 1279 days
#2 posted 06-19-2018 03:34 AM
I would glue the entire length. Length should be stable. “Breadboard” ends across the width of solid wood needs space to expand/contract.
View waho6o9's profile
waho6o9
8475 posts in 2747 days
#3 posted 06-19-2018 04:19 AM
Put a seal coat on both pieces, like shellac or primer, but not in the glue joint and when it’s dry glue it and clamp it up.
View jerryminer's profile
jerryminer
944 posts in 1611 days
#4 posted 06-19-2018 05:01 AM
Bill, I’ve been gluing solid wood to plywood for decades without a failure. (Common for kitchen cabinet shelves etc.) As JBrow said above, wood movement along the length is negligible. Glue the whole length.
williamhdixon
9 posts in 400 days
#5 posted 06-19-2018 11:23 AM
Thanks all. That makes sense.
View bondogaposis's profile
bondogaposis
5039 posts in 2521 days
#6 posted 06-19-2018 01:38 PM
Glue it up the the whole length. Wood doesn’t move in length, just like the plywood. This is a very common practice.
-- Bondo Gaposis
View rwe2156's profile
rwe2156
3133 posts in 1651 days
#7 posted 06-19-2018 01:43 PM
Question answered.
I would add you do not need a T&G.
I’ve had no problems gluing solid wood edging to plywood with butt joints.
View Gene Howe's profile
Gene Howe
10970 posts in 3599 days
#8 posted 06-19-2018 04:16 PM
Question answered.
I ve had no problems gluing solid wood edging to plywood with butt joints.
- rwe2156
Ditto
View enazle's profile
enazle
66 posts in 178 days
#9 posted 06-19-2018 04:35 PM
One thing, make sure the plywood is laying flat when you glue the strip on. If it has any warp, bow or curve the band will freeze it like that. If the board has a little bow, force it flat when you glue the band in place and it will stay that way.
View DBDesigns's profile
DBDesigns
156 posts in 168 days
#10 posted 06-19-2018 07:35 PM
I agree with most of the opinions above but I would add one suggestion. Plywood will soak up glue at different rates based on the grain direction of different laminations and gaps in the grain edges. By the nature of the product, you have end grain and side grain on the same edge. Consider putting a layer of glue onto the edge and let it soak in before you do your final glue and clamp operation.
-- I remember when Grateful wasn't Dead
View Redoak49's profile
Redoak49
3591 posts in 2159 days
#11 posted 06-19-2018 08:31 PM
I normally only glue a 1/4 -1/2” solid wood strip to plywood. I will use a thin brad nail to help locate the strip and then clamp using blue masking tape. If the edges are smooth, the tape is good enough for clamping.
