need help removing outlet box
Forum topic by Karda posted 06-19-2018 01:25 AM 569 views 0 times favorited 23 replies Add to Favorites Watch
View Karda's profile
Karda
1134 posts in 606 days
06-19-2018 01:25 AM
Hi, I have a jury rigged electrical box under my porch. I don’t know who put this he but he was on drugs, this is not anything any competent builder would do. The box was put under the house build on, that part is ok, the box is nailed to a piece of @ x 8 about 2 ft long that is propped on a plastic flower pot that is on a piece of sinder block. What appears to be a wall in back of it is a flake board box covering so air ducts so is not solid. What I want to do is unnail the box and screw it to the 2×4 like it should have been to begin with. However how can I get the nails out. There is nothing solid to pound against any ideas,
23 replies so far
View josephf's profile
josephf
200 posts in 2149 days
#1 posted 06-19-2018 01:35 AM
take a chisel and splinter the board /split it apart . as you pull pieces away nails are left hanging
View BlasterStumps's profile
BlasterStumps
758 posts in 492 days
#2 posted 06-19-2018 01:42 AM
Once I had it de-energized, I would take the cover off and slide a sawzall blade in between the box and the block of wood and cut the nails off. That is if I was trying to save the blocking that all of that is providing.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View Dark_Lightning's profile
Dark_Lightning
3171 posts in 3161 days
#3 posted 06-19-2018 01:49 AM
Also, if that box feeds outdoor electrical items, it is required by code (at least where I live) to be a GFCI type.
-- Random Orbital Nailer
woodbutcherbynight
5266 posts in 2461 days
#4 posted 06-19-2018 01:52 AM
- BlasterStumps
Have pulled many this way that would not pry off. Key here is power must be OFF. 110 is lethal don’t let anyone fool you.
View jbay's profile (online now)
jbay
2425 posts in 952 days
#5 posted 06-19-2018 01:55 AM
Power off, un wire the outlet and remove the wire from the box.
Mount a new box within range of the existing wire and put in a new outlet.
Karda
#6 posted 06-19-2018 02:12 AM
thanks for your suggestions I kinda like the new box idea but don’t want to turn of the electrial for that long but probably will I think there is enough wire,. Another question this is a totaly enclosed area is the outdoor cover necessary thanks Mike
View jonah's profile
jonah
1770 posts in 3351 days
#7 posted 06-19-2018 02:50 AM
If it’s outdoors, it needs an outdoor cover. Get a new box and a new outlet.
View torus's profile
torus
113 posts in 466 days
#8 posted 06-19-2018 02:52 AM
thanks for your suggestions I kinda like the new box idea but don t want to turn of the electrial for that long
The time is the same or even faster. Do a new box.
is the outdoor cover necessary?
bugs and spiders?
-- "It's getting better..." - put this on my RIP stone!
BlasterStumps
#9 posted 06-19-2018 03:11 AM
what’s the problem with de-energizing the wire for a while?
I used to rubber glove 7200-12470 V out of an insulated aerial basket and; I have done some residential wiring. I won’t take chances with energized low voltage. Not worth it.
Karda
#10 posted 06-19-2018 03:16 AM
guess I don’t have a choice
View John Smith's profile
John Smith
1121 posts in 215 days
#11 posted 06-19-2018 12:38 PM
I don’t know if it is just Florida, or the official NEC code.
but, in my area, all outside outlets must be in a waterproof box
as well as a GFCI receptacle. the whole job takes less than 5 minutes.
X2 with the sawzall and metal blade.
-- Graduated Valedictorian from the University of HardKnocks --
View Fresch's profile
Fresch
265 posts in 1973 days
#12 posted 06-19-2018 03:18 PM
guess I don t have a choice
- Karda
Turning it off will let you mark it in your loadcenter.
OSHA, if you were employed as an electrician, requires it to be turned off.
More people die due to 120volt shock.
New box, gfi, cover. 1/2 hr. job max. including turning on and off.
View clin's profile
clin
882 posts in 1049 days
#13 posted 06-19-2018 04:31 PM
Power off, new box. I can’t see why the power would need to be off for more than 30 minutes. Perhaps you could get the new box mounted and ready, before touching the old. And is there something else on the circuit that is power critical?
I can’t tell from the photo if you need to get the old stuff out of the way before the new goes in. But, from your description, it sounds like the 2×8 is just wedged in and held up by the pot. So sounds trivial to remove the whole thing.
-- Clin
Karda
#14 posted 06-20-2018 05:16 AM
what I would like to do is remove the nails and turn the box around and screw to the stud, but it looks like it would take more time to do that than to replace the box
View TheFridge's profile
TheFridge
9708 posts in 1539 days
#15 posted 06-20-2018 12:38 PM
I’d pry a little bit with a screwdriver. Not too much. Cast aluminum likes to break pretty easy. If it’s plastic I wouldn’t try it.
And/or use lineman’s pliers the twist the nail out. Or out enough to cut it with lineman’s or sawzall. Or a hacksaw blade. That goes faster than one might think.
Or just break it and get a new box.
