Building picture frame
Forum topic by Hornnumb2 posted 06-18-2018 03:56 PM 420 views 0 times favorited 11 replies Add to Favorites Watch
View Hornnumb2's profile
Hornnumb2
27 posts in 878 days
06-18-2018 03:56 PM
I need to make a frame for a stained glass panel, it will be made out of 3/4 hardwood by 2in with miter corners. There will be a groove down the center to accept the panel. What is the best way to get a strong joint on my 45’s. The panel is 36×16. Thanks Michael
11 replies so far
View builtinbkyn's profile
builtinbkyn
2490 posts in 990 days
#1 posted 06-18-2018 04:00 PM
You probably want to use a half-lap miter:. 3/4” seems a bit lightweight for a panel that size unless it’s going to be supported by an outer frame. Maybe someone here that does stained glass and has done this, can offer some better solutions.
-- Bill, Yo!......in Brooklyn & Steel City :)
View Rich's profile
Rich
3173 posts in 639 days
#2 posted 06-18-2018 05:06 PM
- builtinbkyn
+1. Either that or some form of spline, either internal, or a key. The key could be made of a contrasting wood for visual effect.
The bottom line is you need some long grain to long grain surface for gluing. Short of that, you need some type of mechanical fastener.
View EarlS's profile
EarlS
1239 posts in 2398 days
#3 posted 06-18-2018 05:19 PM
Options for splines are endless and they really can dress up a frame. You could pin a half lap joint and get a Craftsman or G&G look. You could also try variations on a bridle joint or finger joint. I seem to recall seeing a really interesting miter/half lap combination corner. Try doing a google search and then look in the images tab.
You can also use different thickness wood for the top/bottom vs. the sides. Again – the possibilities are endless. Find something that will match up with the style of the stained glass.
You might consider putting a colored backing board behind the glass to bring out the colors in the glass. I have some stained glass panels in the doors of a cabinet that look amazing with light coming through them but since I don’t have a light source behind the glass the awesome colors are missing. I have seen LED strings that are made for use in picture frames if you want to really go all out. Hope this helps.
woodbutcherbynight
5216 posts in 2459 days
#4 posted 06-18-2018 05:41 PM
Your frame sounds good and any of the joint suggestions would work. Considering the weight of this panel and the desire to not have failed joints I suggest a back. You could paint or stain it so the glass stands out better. Various way to trim around the edge so 1/4 plywood would suffice with some sort of dressing to cover it where it shows. Use screws to attach to the frame from the back. Or dowels if so desired.
View John Smith's profile
John Smith
1102 posts in 212 days
#5 posted 06-18-2018 10:46 PM
Michael, just out of curiosity, how are you going to display
this glass piece once you get it mounted?
hang it on the wall like a picture frame ?
mounted in a window or door ?
will the glass fit into the flat side or edge side of the frame ?
do you have any photos of your glass piece ?
-- Graduated Valedictorian from the University of HardKnocks --
builtinbkyn
#6 posted 06-18-2018 11:04 PM
John you asked all the right questions that some of us should have asked before making any suggestions. I guess “picture frame” made me assume it would be on the flat, but maybe not, as you illustrated. If not, at the very least, that would certainly change the joinery. Now I have to follow this thread and hope we get the OP to respond.
- John Smith
View Andybb's profile
Andybb
1060 posts in 653 days
#7 posted 06-18-2018 11:06 PM
+1 For splines. Attractive and strong.
-- Andy - Seattle USA
View grnjames's profile
grnjames
14 posts in 45 days
#8 posted 06-25-2018 08:08 AM
That looks sturdy and well.
-- Installation of headache rack for wood panel support I got from http://4wheelonline.com/Truck_Headache_Racks.48833
Hornnumb2
#9 posted 06-25-2018 01:48 PM
it will be hung in a window. so splines it is.
View Rick's profile
Rick
9905 posts in 3082 days
#10 posted 06-27-2018 11:13 PM
- Andybb
+ 2 For the Splines. Best way to go!
-- Your Assertiveness Training Is Beginning To Interfere With My Anger Management!
View theart's profile
theart
35 posts in 604 days
#11 posted 06-28-2018 11:58 AM
I like splined miters. I would also rabbet the back and use glazier’s points to hold the glass in instead of cutting a groove. If the frame is going to be seen from both sides, you can use strips of wood tacked in with brads instead of points. Someday, you might need to get the glass back out of the frame, and with a groove that’s going to be nearly impossible.
