Tips for Mobile Bases
Forum topic by woodbutcherbynight posted 06-17-2018 05:21 PM 725 views 0 times favorited 14 replies Add to Favorites Watch
woodbutcherbynight
5545 posts in 2523 days
06-17-2018 05:21 PM
Topic tags/keywords: resource tip question
There are many different ways to make mobile bases. From the design, based on strength for heavy work benches to lighter duty utility style type bases. I read a lot of posts about going all mobile in shops. Pro’s and con’s for both sides of this as well as some built in and some mobile. In a recent discussion over breakfast a buddy pointed out a interesting issue that I also have. What do you do for shops built on old patios or shops with uneven ground? In my shop (built by previous owner on a 16×20 patio) the drop one direction is ½ inch to 5/8 inch per foot in some places and the opposite direction about ¼ inch.
So do you build the base and add leveling blocks after you put it in place? This way when you move it is level elsewhere, or level again when moved? Or built to be level where you want it and when moved if ever deal with it again?
In making this a discussion let’s also add how size is a consideration. Lessons learned on builds and pictures of what you have done with yours. Other members have similar issues, or may in the future and might benefit from tips we all can offer here.
14 replies so far
View ralbuck's profile
ralbuck
4999 posts in 2381 days
#1 posted 06-17-2018 05:40 PM
One idea would be to make blocks for the places that you normally position that tool. They could be color coded to be able to remember which goes where easier too.
I am thinking a U shaped that would be easy to position and remove; yet still stay! A little heavy foam glued to the bottoms would also help. Think a door stop with sides that cradle the wheels they need to support.
I have never been unhappy that I built something STURDY! I have been when it was to lightly made though. I have reinforced factory stands too.
Hope this idea helps.
-- Wood rescue is good for the environment and me! just rjR
View DocSavage45's profile
DocSavage45
8683 posts in 2957 days
#2 posted 06-17-2018 08:45 PM
My shop is similar as I screwed up by not doing the floor first in the rebuild. Have heavy duty grizzly mobil bases for very heavy equipment like my cabinet saw. Added half inch spacers to the casters when I upgraded to a 17 inch bandsaw. Tested it in rolling over humps before setting my new bandsaw on the old 14 inch saw’s base. Works great.
Due to increase in equipment and size of equipment the fixed benches are becoming mobile benches
*https://www.youtube.com/watch?v=sIxPpqpY12k*
-- Cau Haus Designs, Thomas J. Tieffenbacher
woodbutcherbynight
#3 posted 06-17-2018 09:05 PM
My shop is similar as I screwed up by not doing the floor first in the rebuild. Have heavy duty grizzly mobil bases for very heavy equipment like my cabinet saw. Added half inch spacers to the casters when I upgraded to a 17 inch bandsaw. Tested it in rolling over humps before setting my new bandsaw on the old 14 inch saw s base. Works great.
- DocSavage45
I believe many of us are having to rethink going mobile as we get larger machines but our shops remain same size.
LOL
View hairy's profile
hairy
2750 posts in 3646 days
#4 posted 06-17-2018 09:47 PM
In my basement shop all the floor slopes towards the drain. I built this base with leveling built in.
http://lumberjocks.com/projects/15760
-- My reality check bounced...
DocSavage45
#5 posted 06-17-2018 09:59 PM
Hope you get more ideas. LOL!
Have a design for my outfeed table/project table w/castors similar to hairy’s
View Shamb3's profile
Shamb3
23 posts in 296 days
#6 posted 06-17-2018 11:29 PM
I am a fan of this bench design with some leveling feet on it. http://lumberjocks.com/projects/325409
You could slide leveling blocks under the legs before setting it down for other locations.
View Jim Jakosh's profile
Jim Jakosh
21101 posts in 3220 days
#7 posted 06-17-2018 11:40 PM
Any base will not fit well on an uneven floor. I’d suggest making wedges to drive in to take the wobble out. On my table saw, I put some ears with threads in them and then I made long rods with threads on the bottom end and rubber foot at the tip and a crank on the top end. I did this to lock it in place, but it would also work for an uneven floor situation!!
Cheers, Jim
woodbutcherbynight
#8 posted 06-18-2018 01:35 AM
- hairy
Interesting design!! So if you want to move it just raise the feet up until wheels touch then move as needed?
woodbutcherbynight
#9 posted 06-18-2018 01:36 AM
- Shamb3
I saw this and my only issue was it takes up alot of valuable space under the table. As far as design though it is sturdy and would handle a heavy load.
woodbutcherbynight
#10 posted 06-18-2018 01:37 AM
Have a design for my outfeed table/project table w/castors similar to hairy s
- DocSavage45
Yeah I am looking!!! Besides this is not a topic I found much discussion on as of late. Might give fresh ideas for everyone.
woodbutcherbynight
#11 posted 06-18-2018 01:39 AM
Any base will not fit well on an uneven floor. I d suggest making wedges to drive in to take the wobble out. On my table saw, I put some ears with threads in them and then I made long rods with threads on the bottom end and rubber foot at the tip and a crank on the top end. I did this to lock it in place, but it would also work for an uneven floor situation!!
Cheers, Jim
- Jim Jakosh
I like this idea, have to look into if I can adapt it to the wheels themselves or find a way to have it inside the cabinet. Say remove bottom drawer and raise and lower as needed.
hairy
#12 posted 06-19-2018 12:59 PM
- hairy
- woodbutcherbynight
Yes. The bottom side of the angle iron has a nut welded on. There is a jam nut to maintain placement on the top side. Roll it into position, raise the base and level it as you raise it.
View Bill_Steele's profile
Bill_Steele
402 posts in 1846 days
#13 posted 06-19-2018 03:50 PM
I used something very similar to these leg levelers and when I want to raise or lower them I use a cordless drill with a hex bit and a flexible extension. I wouldn’t want to raise and lower them frequently because it takes a few minutes—but it sure beats doing them by hand.
woodbutcherbynight
#14 posted 06-20-2018 01:41 AM
I used something very similar to these leg levelers and when I want to raise or lower them I use a cordless drill with a hex bit and a flexible extension. I wouldn t want to raise and lower them frequently because it takes a few minutes—but it sure beats doing them by hand.
- Bill_Steele
Well some cabinets we only move in a great while when doing, wait for it…. Clean – Up!
So while cumbersome this idea may be best application.
