Table Saw Fence Alignment
Forum topic by BroncoBrian posted 06-17-2018 03:16 AM 960 views 1 time favorited 32 replies Add to Favorites Watch
View BroncoBrian's profile
BroncoBrian
754 posts in 2077 days
06-17-2018 03:16 AM
Good evening everyone!
I know there are old threads about this, but I thought it was time for a new poll/argument.
Fence to the miter slot… Dead on or 1/128-1/64 out at the back?
I am about that measurement out right now and am curious what you all think. I know the distance between the front of the blade and the fence (at that point) is the width of the cut.
Thanks, BD
-- I'd like to see a forklift lift a crate of forks. It'd be so damn literal!
32 replies so far
View jbay's profile (online now)
jbay
2588 posts in 1017 days
#1 posted 06-17-2018 03:34 AM
Good evening everyone! I thought it was time for a new poll/argument.
Thanks, BD
- BroncoBrian
I set mine Dead on, (maybe 128th out at most)
View Joe Lyddon's profile
Joe Lyddon
10240 posts in 4170 days
#2 posted 06-17-2018 04:02 AM
Where’s the OLD one?
Why didn’t you post to it… to bring it back to life? LOL
View Rich's profile
Rich
3536 posts in 707 days
#3 posted 06-17-2018 06:11 AM
I never thought about it or measured it. My saw cuts great as-is. Crap, I’m not sure I can sleep tonight now worrying about it.
View knotscott's profile
knotscott
8121 posts in 3494 days
#4 posted 06-17-2018 10:53 AM
I was taught to set mine with a tiny fraction toe out to offset any possible deviations of the fence, but I wouldn’t do it if I cut on both sides.
BroncoBrian
#5 posted 06-17-2018 03:40 PM
Joe: Because that is obnoxious! LOL. The last thread I found was 2007.
JBAY: Which saw/fence do you use?
Rich: Did you check this morning?
Knotscott: That is about where I am, just barely out and for the same reason. I have the better of the 2 Sawstop fences and there is definitely the slightest wave visible, so it seems to be the safest method. Would need to be adjusted if I cut from the left of the blade.
View Charlie H.'s profile
Charlie H.
260 posts in 768 days
#6 posted 06-17-2018 03:48 PM
I have mine toed out a few 1000ths
-- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.---------
View fuigb's profile
fuigb
506 posts in 3076 days
#7 posted 06-17-2018 04:09 PM
Dead-even, front and back of the blade. My saw is a Bosch 4100 where the factory fence alignnment provisions blow. Literally. So I use squares and set-up blocks to tweak my fence just right for each new cut. It’d be different if I had a proper cabinet saw but I have what I have and this system works for me.
-- - Crud. Go tell your mother that I need a Band-aid.
View pontic's profile
pontic
626 posts in 727 days
#8 posted 06-17-2018 04:18 PM
jet Xacta fence. Adjusted to 1/64” toe out. Re calibrate when I cut with the fence on the left side. Xacta fences are so easy to adjust, I check it often. It never seems to go off of where I set it. Since I don’t think Most of us can tell when a piece is 1/64th off I don’t get it much tighter than that.
-- Illigitimii non carburundum sum
jbay
#9 posted 06-17-2018 04:29 PM
- BroncoBrian
I have a Biesemeyer.
I cut a lot of melamine, so if the fence isn’t dead on it will/can chip the off cut which often is the next piece.
Hardwoods don’t matter as much, but since I do cut melamine I don’t bother resetting my fence all the time
View Rich's profile
Rich
#10 posted 06-17-2018 05:06 PM
- BroncoBrian
Yep. Perfectly aligned. I don’t recall ever touching it since I set it up twenty years ago. It’s a Delta Unifence and it’d take a sledge hammer to knock it out of alignment.
BroncoBrian
#11 posted 06-17-2018 05:29 PM
jet Xacta fence. Adjusted to 1/64” toe out. Re calibrate when I cut with the fence on the left side. Xacta fences are so easy to adjust, I check it often. It never seems to go off of where I set it. Since I don t think Most of us can tell when a piece is 1/64th off I don t get it much tighter than that.
- pontic
The cut is only made one time at the front of the blade. In theory, straight or out at the far end should not make a different cut. Plus, 1/128 to 1/64 over the length of the fence is almost nothing over the length of the blade.
View Rich's profile
Rich
#12 posted 06-17-2018 05:41 PM
- BroncoBrian
I’ve never really thought about it, but what you’re saying makes some sense. Seems like parallel would be ideal and some toe-out in the rear tolerable, while any toe-in could be disastrous.
View Woodknack's profile
Woodknack
12336 posts in 2498 days
#13 posted 06-17-2018 06:21 PM
Mine is as close to dead on as I can get it because I occasionally use both sides.
Joe Lyddon
#14 posted 06-17-2018 06:50 PM
What is wrong with the good ole Square and Parallel? (which makes 100% sense to me) ???
woodbutcherbynight
5545 posts in 2527 days
#15 posted 06-18-2018 02:00 AM
- Joe Lyddon
Look Joe we are making space shuttles here. It has to be absolute dead on or the ship falls like a rock.
ROFL
showing 1 through 15 of 32 replies
