Why are longer jointer tables better?
Forum topic by weekendwoodguy posted 06-17-2018 01:52 AM 1042 views 0 times favorited 16 replies Add to Favorites Watch
View weekendwoodguy's profile
weekendwoodguy
16 posts in 218 days
06-17-2018 01:52 AM
Topic tags/keywords: question jointer jointing beginner joining
Hello all I’ve been lurking for some time now but this is my first post here.
I’ve read a number of posts talking about jointers and many recommendations from people who say to buy the longest tables you can afford or have space for. I totally understand how a longer table or a roller support would make it safer to handle a longer board but I just can’t conceptualize why longer tables are needed to reliably joint longer boards. I have read a few explanations about this but I didn’t really find them that clear to be honest.
Can someone offer a simple example of a situation where a short jointer would not give you good results due to the table length?
16 replies so far
View pintodeluxe's profile
pintodeluxe
5781 posts in 2984 days
#1 posted 06-17-2018 02:47 AM
Longer jointer beds give a better reference surface to straighten lumber. This is especially true of the infeed table.
Remember you are jointing rough lumber that is sometimes bowed. Not only are longer beds helpful for more accurate milling, but they also let you joint longer boards with ease.
I think the overall length on my 8” jointer is about 74” and that’s perfect for the work I do. I used to have a 6” jointer that was much shorter, and it was very difficult to mill long boards.
View TheFridge's profile
TheFridge
10493 posts in 1656 days
#2 posted 06-17-2018 02:48 AM
It’s about how much of the board is able to register on the tables. You’re thinking it’s just for support but that’s not it’s only purpose.
Edit: even if you had indeed/outfeed rollers, it makes it easier to handle stock but it doesn’t give you a continuous flat surface to register stock against.
View BroncoBrian's profile
BroncoBrian
830 posts in 2129 days
#3 posted 06-17-2018 03:29 AM
^^Yep^^
I went with a Jet 8” instead of a Powematic because the length was shorter and I needed to make it more maneuverable in my garage. Now I know why the PM was longer and sometimes wish I went with that one instead. The difference in space is not that significant and the mobile base I made is great and pivots easily.
For longer boards, the longer tables would be more accurate with fewer passes. But for most work I am doing, it is fine.
Fridge is right, the length gives you a longer flat surface to maximize the straight edge, it is not about support. If you have a board that needs that mush support, then you need something bigger.
-- I think they could take sesame seeds off the market and I wouldn't even care. I can't imagine five years from now saying, "Man, remember sesame seeds? What happened? All the buns are blank."
woodbutcherbynight
5588 posts in 2579 days
#4 posted 06-17-2018 03:31 AM
My kids refer to this tool as a aircraft carrier…....
LOL
View Aj2's profile
Aj2
1783 posts in 1968 days
#5 posted 06-17-2018 03:48 AM
They will only work better if they are flat and coplane.If they are not you will have to make up the difference will skills and know how.
This is the reason a used jointer is sometime a better choice then new since you can inspect the tables before you haul it home. With a reliable straight edge.
-- Aj
View Rich's profile
Rich
3748 posts in 760 days
#6 posted 06-17-2018 06:09 AM
If you think about it in reverse, how well would a 4” jointer straighten a board? Not very well. I’ve got an old Jet JJ-6 that I’ve had forever. Not especially long, but I joint 80” door stiles on it all the time and they come out perfectly straight.
As long as you support the full length of the board level with the bed of the jointer, it doesn’t matter how long it is. Longer beds just make that job easier.
weekendwoodguy
#7 posted 06-17-2018 01:14 PM
Thanks for all the responses. I see what your all saying about the longer tables bring a better reference.
So if I was trying to joint a bowed 8’ board on a jointer with a 48” overall length would it be impossible or just really frustrating?
I guess what I still don’t get is why so much of the board needs to reference the table at one time especially considering that guys using hand planes only have about 20-24” of reference.
View bondogaposis's profile
bondogaposis
5043 posts in 2521 days
#8 posted 06-17-2018 01:24 PM
You can only effectively joint a board that is roughly twice the length of the infeed and outfeed tables combined.
-- Bondo Gaposis
View Rich's profile
Rich
#9 posted 06-17-2018 01:42 PM
So if I was trying to joint a bowed 8’ board on a jointer with a 48” overall length would it be impossible or just really frustrating? I guess what I still don’t get is why so much of the board needs to reference the table at one time especially considering that guys using hand planes only have about 20-24” of reference.
- weekendwoodguy
It wouldn’t even be frustrating. It’d be easy, and it really doesn’t matter if it’s bowed or not, that will just affect the amount of wood you remove and is a good reason to choose carefully at the lumber yard. My Jet JJ-6 is 42” long and, like I said, I’ve jointed literally hundreds of 80” residential door stiles. Just set up in feed and out feed support rollers and it’ll be easy.
Good analogy on the hand plane jointer. You are precisely correct.
Obviously, when it comes to a jointer, bigger is better. Get whatever you can afford and fit in your shop.
View GR8HUNTER's profile (online now)
GR8HUNTER
4897 posts in 883 days
#10 posted 06-17-2018 01:59 PM
what it really means get what you can afford
some guys dont even know how to jiont a board properly :<))
dont forget it has to fit the shop also :<((
weekendwoodguy
#11 posted 06-17-2018 02:16 PM
Ok thanks for the advice and info. Im in the market for a used jointer and I’m sure I’ll be back with more questions.
BroncoBrian
#12 posted 06-17-2018 03:59 PM
Curious… would the shorter bed actually remove more from the board before it is flat? Or is it that the angle will change each time you make a pass because the back of the board will rise as you slide left to right? The green is a short table, purple is longer.
Also, would it matter less if you flipped this over to joint the other side?
TheFridge
#13 posted 06-17-2018 04:35 PM
I run it belly facing down. If for some reason I have to run it like in the above pics I’ll knock the ends down so it doesn’t hang below the table.
Even running it like that you’ll eventually get it straight.
pintodeluxe
#14 posted 06-17-2018 05:33 PM
You should joint boards with the concave side down as pictured. Otherwise the board can rock and you’ll lose your reference surface. There are exceptions to every rule, but it usually holds true.
View Rich's profile
Rich
#15 posted 06-17-2018 05:45 PM
You should joint boards with the concave side down as pictured. Otherwise the board can rock and you ll lose your reference surface. There are exceptions to every rule, but it usually holds true.
- pintodeluxe
I’ve always heard that too, but if you’re careful to keep the pressure on the flat part that gets created pretty quickly, then it doesn’t rock. I try to keep it concave side down, but sometimes there isn’t a choice, so learning how to manage it convex side down is worthwhile.
