Router Table & Fence mismatch
Forum topic by TMcG posted 06-21-2011 03:55 AM 2270 views 0 times favorited 10 replies Add to Favorites Watch
View TMcG's profile
TMcG
191 posts in 2963 days
06-21-2011 03:55 AM
Topic tags/keywords: router table fence
So, I bought this router table
and this fence
Problem is that the slots in the aluminum fence and the slots in the table don’t line up so I’m sorta wondering what my options are
1. Drill holes in the fence and file out the slots ?
2. Extend the fence slots some other way ?
I guess my question in general is, what is the easiest/simplest/most idiot proof way to work aluminium ?
Thanks
-- http://wood.mcgivern.org
10 replies so far
View crank49's profile
crank49
4030 posts in 2933 days
#1 posted 06-21-2011 04:10 AM
Well it aint easy. Aluminum is a gummy metal. It likes to stick in saw teeth, files, etc. I’m sure there must be a preffered lubricant but I don’t know what it is right off hand. I do know it will turn a band saw blade into a band. I had to take the blade off and pick the aluminum out of each tooth with jeweler’s pliers. A real PITA.
View Steve2's profile
Steve2
75 posts in 3533 days
#2 posted 06-21-2011 06:21 AM
FST makes a blade for aluminum cuts perfectly clean, none of the problems mentioned. Onsrud makes router bits for aluminum. Same thing.
-- Regards, Steve2
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3069 days
#3 posted 06-21-2011 07:11 AM
I’ll revel the highly technical secret to keep saw blades from gumming up with aluminum….Ready?
1/4 cup of dish soap in water with a squirt bottle. Be sure to clean the cast iron immediately.
View TMcG's profile
TMcG
#4 posted 06-24-2011 12:42 PM
Hmm, not having any possum fat or racoon grease quite to hand, I guess it’s drill and file time !!
Thanks guys
View PineInTheAsh's profile
PineInTheAsh
404 posts in 3230 days
#5 posted 06-24-2011 01:21 PM
3. Return one or both.
View Gene Howe's profile
Gene Howe
10341 posts in 3391 days
#6 posted 06-24-2011 02:01 PM
Return both and purchase a compatible set.
View Howie's profile
Howie
2656 posts in 2885 days
#7 posted 06-25-2011 02:01 AM
I’d drill new holes. No big deal.
-- Life is good.
View PurpLev's profile
PurpLev
8534 posts in 3611 days
#8 posted 06-25-2011 02:52 AM
drill holes in the aluminum fence to match the table – no biggy.
FYI, lubricant for Aluminum is WD40. better yet – clamp the aluminum part between 2 small wooden boards and drill though that – it’ll keep the holes in the aluminum nice and clean – no need to file.
View quartrsawn's profile
quartrsawn
146 posts in 3175 days
#9 posted 06-25-2011 02:56 AM
Rather than drill/file , I used a 1/2 ’” downcut spiral bit in my plunge router to make the fence slots in my table.I clamped a temporary fence to the table edge to make straight/smooth slots .My table is a sink cutout from a laminate counter top and a Rockler router fence,with a Rousseau router plate. I lock down th fence with toilet bolts in the slots and T-knobs.
-- Nat - West Sayville,L.I., NY
View ChefHDAN's profile
ChefHDAN
1047 posts in 2812 days
#10 posted 06-25-2011 03:03 AM
I’d buy T track & build my own but I’m cheap that way!
