Purpleheart
Forum topic by Grantman posted 03-28-2008 01:10 PM 1123 views 0 times favorited 5 replies Add to Favorites Watch
View Grantman's profile
Grantman
113 posts in 3994 days
03-28-2008 01:10 PM
Topic tags/keywords: wood purpleheart finishing question
Made my first project in purpleheart last month, a yoga bench for my wife. It was purple – light grape jelly purple – at the lumber yard when I bought it. Working it, the pieces immediately turned brown (expected) and within a day or so, turned a red-violet color, kind of like a glass of diluted Merlot.
How long will it take to turn back to that purple color? Is there anything I can do to accelerate the process? Do I need to expose it to sunlight?
Any thoughts would be greatly appreciated.
Thanks.
5 replies so far
View DannyBoy's profile
DannyBoy
521 posts in 3833 days
#1 posted 03-28-2008 02:53 PM
My experience has been that if you are using a dull blade or otherwise “burning” the wood, it turns black. After I initially cut it, it would be light purple if it didn’t burn. After a few days, the color would deepen and it would return to a nice deep “merlot” color. That should be it’s natural look.
If you have used a stain or sealer then your results are going to be dependent on the color of the product and whether the wood can breath.
I’m probably wrong on that but that’s what I think…
-- He said wood...http://hickbyassociation.blogspot.com/
View GaryK's profile
GaryK
10262 posts in 3956 days
#2 posted 03-28-2008 03:52 PM
I have some purpleheart, and haven’t given much thought to it color changing. I will have to keep that in mind.
View rikkor's profile
rikkor
11295 posts in 3843 days
#3 posted 03-28-2008 04:14 PM
I made my wife a pen of purpleheart and it has darkened. I attributed it to hand oil, but it sounds like it darkens naturally, like cherry does.
View Narayan's profile
Narayan
8 posts in 3692 days
#4 posted 03-29-2008 12:22 AM
If you take a few shavings off it and put it in the sun, it’ll turn bright purple. Or is it take it out of the sun? I don’t remember. :)
I’m not sure what chemical process takes place here, something like oxidization. Anyway, the surface will turn a kind antique brown with time. I don’t remember (it’s been a while since I’ve built anything with purpleheart) if there’s a way to lock in the bright purple through sealing.
Grantman
#5 posted 03-29-2008 11:48 AM
Dannyboy, it’s good to know that the merlot color is what it’s supposed to be for the “final” color. It’s still unfinished (sanded to 220) waiting for it to go back to the light grape jelly color. Maybe I’ll just leave it at that, or put a natural oil on it leave it be. I did use a somewhat dull blade and there was some burning but sanding took it back to the red violet.
Narayan, I put a few pieces in the sun but evidently not long enough…nothing happened. I probably didn’t leave it long enough. You’re thinking ‘antique brown’ will be the final color? Very interesting.
Oh well, I’ll leave the post up over the weekend and see if anyone else chimes in with their experiences.
Thanks, all.
