Hollow table leg
Forum topic by Gareth Jordaan posted 06-14-2018 04:59 PM 446 views 0 times favorited 5 replies Add to Favorites Watch
View Gareth Jordaan's profile
Gareth Jordaan
1 post in 222 days
06-14-2018 04:59 PM
Topic tags/keywords: question pine
Hello All
I have been asked to make this leg for the dining room table I am making for my customer. The customer has asked because of his budget, that I must Not make these legs out of a solid block of wood. He wants to save money by me making these legs look like they were cut out of a solid block of wood. If this was a square leg, it would be easy, but because of the shape, I am stumped. Has anybody done anything like this before? Please advise? Thank you in advance!
5 replies so far
View Loren's profile
10477 posts in 3888 days
#1 posted 06-14-2018 05:06 PM
Save the customer money by making a leg shape
you know how to make efficiently.
People on here have inquired many times about
this general style of pedestal leg and I’ve never
seen a quick & easy solution proposed. You’ll
have to remove the waste, refine the shape with
hand tools and do a lot of sanding.
View johnstoneb's profile
johnstoneb
3072 posts in 2413 days
#2 posted 06-14-2018 05:34 PM
Glue up blocks from const. grade lumber. Shape it then veneer it.
-- Bruce, Boise, ID
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#3 posted 06-14-2018 05:37 PM
You can see from the picture that the leg is glued up from several pieces of pine at least three that I can see. Do you have a bandsaw that has the capacity to cut the leg? If so it is pretty straight forward. Laminate a block of wood sufficient size, square it up. Then cut the profile for the main part on 2 adjacent sides, save the waste and use double sided tape to tape the waste back in place then cut the opposite sides to match other sides. Then begin sanding and sanding and sanding. I would not attempt to make it hollow, any savings in cheap pine would be eaten up by greatly increasing the labor and time to make it.
-- Bondo Gaposis
View JADobson's profile
JADobson
1335 posts in 2351 days
#4 posted 06-14-2018 07:10 PM
- bondogaposis
+1 customer seems to think that material costs are an easy place to save money. Not true. Your time is what adds up the fastest and making it hollow is going to take a lot longer.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View AlaskaGuy's profile
AlaskaGuy
5000 posts in 2549 days
#5 posted 06-14-2018 09:36 PM
Not your exact leg but may give you some ideas on building such a leg.
https://youtu.be/dyqq9pQ7kHg
I wish I could buy a Cadalic for the price of a VW.
