HF 2HP DC Using 50ft Extension Cord = Lose Power?
Forum topic by StainedSlippers posted 06-19-2011 08:35 PM 2599 views 0 times favorited 16 replies Add to Favorites Watch
View StainedSlippers's profile
StainedSlippers
8 posts in 2806 days
06-19-2011 08:35 PM
Hey Guys,
I just bought the Harbor Freight 2HP Dust Collector and so far just have it hooked to my Griz G0715P tablesaw. Will connect to Router table, Band saw, jointer…I am using a 50ft. 15 amp extension cord with a woods remote control setup. Do I lose any power by using the extension cord?
As always, thanks again for the good info…
16 replies so far
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3706 days
#1 posted 06-19-2011 08:46 PM
Yes power is affected by using a long power cord. Alistair
View Loren's profile
10477 posts in 3768 days
#2 posted 06-19-2011 08:46 PM
Probably yes. Use a shorter extension cord if possible.
View NBeener's profile
NBeener
4816 posts in 3294 days
#3 posted 06-19-2011 09:10 PM
My gut agrees, but … wanna’ do the math ??
LINK
-- -- Neil
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3279 days
#4 posted 06-20-2011 12:10 AM
2% voltage drop at most, or 1% with a cord half that length. IMHO, that’s pretty insignificant.
-- jay, www.allaboutastro.com
StainedSlippers
#5 posted 06-20-2011 01:06 AM
(IMHO?) Ok so 2% voltage drop…right now it has a 5ft hose from the saw to the collector and will probably be 5 ft to the router table and 5 ft to bandsaw. If I were to move the dust collector closer to the outlet, I would have to increase my hoses to the machines…probably 10-15 ft each…wouldn’t I also lose suction there with the longer hoses?
View Paul Pomerleau's profile
Paul Pomerleau
309 posts in 2814 days
#6 posted 06-20-2011 01:58 AM
IMHO = In My Honest Opinion.
-- Close to Ottawa Ontario Canada
#7 posted 06-20-2011 02:28 AM
Really in my experience you’re just more likely to blow your breaker with
the DC. If it runs, it runs.
StainedSlippers
#8 posted 06-20-2011 03:23 AM
Great, thanks fellas…Since a 2% voltage drop sounds pretty minimal, I think I’m going to try and roll with what I have instead of rearranging the shop…as always, thanks for the great feedback.
View D_Allen's profile
D_Allen
495 posts in 2905 days
#9 posted 06-20-2011 03:27 AM
I had a small air compressor hooked up to a 50 ft extension cord a week ago and it just would not pull enough cutrrent to keep it running. I did trip the breaker eventually, but before that it just ran slower and heated up the cord.
-- Website is finally up and running....www.woodandwrite.com
View dbhost's profile
dbhost
5766 posts in 3352 days
#10 posted 06-20-2011 03:57 AM
The manual says not to use an extension cord. Having said that, I use mine with a 50 foot 12 gauge cord…
View Grandpa's profile
Grandpa
3261 posts in 2796 days
#11 posted 06-20-2011 04:13 AM
I would want a 12 gauge cord if possible but then again most of the receptacles in the U.S. are 15 amp. It would still be better than a 14 ga. cord. Amperage is lost in the cord and length is the enemy. It would also lose amperage if you wired it in hard and had a long run. A long run is a long run. You could just avoid some of the smaller receptacles. When I was working in the design business we supported equipment that would have a 240V motor running on a 208 service. That is voltage though.
View cutmantom's profile
cutmantom
407 posts in 3155 days
#12 posted 06-20-2011 04:39 AM
make sure the cord is at least a 12 gauge or could you wire in a dedicated outlet for the DC, solid copper wire performs better that multistrand extension cords
View Mike Gager's profile
Mike Gager
665 posts in 3388 days
#13 posted 06-20-2011 06:40 AM
i use a 12 gauge cord on mine. i think its only 15ft long though. seems fine
View dpop24's profile
dpop24
115 posts in 2690 days
#14 posted 06-20-2011 07:26 AM
IMHO actually typically means In My Humble Opinion – or at least that’s the way I understand it.
-- If it ain't broke, take it apart and find out why
View knotscott's profile
knotscott
8122 posts in 3496 days
#15 posted 06-20-2011 10:58 AM
The longer cord isn’t doing the motor any favors for long term reliability….shorter and heavier would be better.
