Saw blade for 1/4 plywood draw bottoms
Forum topic by Tim78 posted 06-19-2011 06:19 PM 2391 views 0 times favorited 10 replies Add to Favorites Watch
View Tim78's profile
Tim78
16 posts in 2542 days
06-19-2011 06:19 PM
Topic tags/keywords: tablesaw blade dado
Does anyone know who sells a saw blade that is slightly smaller than 1/4 inch (for use with 1/4 inch plywood)? I would like to make dadoes for draw bottoms on the sides of the drawers with just one pass in the table saw. Thank you in advance.
10 replies so far
View StephenO's profile
StephenO
44 posts in 2510 days
#1 posted 06-19-2011 06:35 PM
Not sure on the saw blade, but I have a set of Rockler router bits that are sized for plywood thicknesses for grooves and dadoes.
-- -Steve, Seattle
View tenontim's profile
tenontim
2131 posts in 3709 days
#2 posted 06-20-2011 12:12 AM
Can you say, “wobble dado” ? That would be a pretty hefty blade, to match the thickness of the metric plywood.
View DLCW's profile
DLCW
530 posts in 2619 days
#3 posted 06-20-2011 12:44 AM
Use a standard combo blade and make two passes. Doing it this way makes for a PERFECT fit.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View neandernormite's profile
neandernormite
37 posts in 2537 days
#4 posted 06-20-2011 01:00 AM
Maybe I do scum work, but for something like a drawer bottom I will use a 1/4 dado blade. The ply it rarely dead flat, that slight bend will hold it in place. Now if I come across a situation where the 1/4” ply is structural, I will two pace it, however, I have never had that situation.
-- The confused powertool using galoot
View WayneC's profile
WayneC
13753 posts in 4062 days
#5 posted 06-20-2011 01:18 AM
Have you thought about a small grooving plane?
10260 posts in 3613 days
#6 posted 06-20-2011 02:21 AM
I had a dado set for awhile called “The Hogger” and what it lacked
in versatility it made up in heavy dutiness. Each side blade had 1/4”
chippers and the inside chippers were 1/4” too…. so I think it could
cut from 1/4” to 1” wide in 1/16” increments – with a pretty flat
bottom.
View Grandpa's profile
Grandpa
3259 posts in 2640 days
#7 posted 06-20-2011 04:31 AM
I have a cheap wobble dado head that I use. It cuts a 3/16 groove when it is at its smallest. Works for me.
View cutmantom's profile
cutmantom
402 posts in 3000 days
#8 posted 06-20-2011 04:45 AM
I have a dado set from HF that starts at 3/16” wide also at a cabinet shop I used to work at they stacked 2 thin kerf saw blades with maybe some shimming to get the desired width, this was mounted on a dedicated tablesaw for drawer boxes
View philip marcou's profile
philip marcou
264 posts in 2562 days
#9 posted 06-20-2011 08:16 AM
Tim, in my opinion if one goes to the trouble of making a drawer then one should use decent quality ply preferably 5 ply or even more. Better quality ply = better consistency eg in thickness. So for 1/4” ply the standard 1/4” dado set or a wobble saw are good and Neandernormite makes a valid point about straightness.
A saw blade with a 1/4” or 6mm kerf is not something I would expect to see for the usual 10 or 12 inch blades….
Maybe on a 24 inch cross cut ….
Might be an idea to check ply thicknesses before buying-someone may be selling 6mm ply and calling it 1/4” (6.35mm) ply….
Tim78
#10 posted 06-21-2011 03:19 AM
Thanks everyone for your replies. I did not realize there were so many options. I like the wobble blade idea.
