Do I Need a Regular Block Plane When I Have a Veritas Low Angle Block Plane
« back to Hand Tools forum
Forum topic by cortes posted 06-13-2018 02:07 PM 3715 views 0 times favorited 15 replies Add to Favorites Watch
View cortes's profile
cortes
7 posts in 17 days
06-13-2018 02:07 PM
Topic tags/keywords: block plane
I’m clearing out some old tools and may sell them or pass them on to a relative. I recently bought a Veritas low angle block plane. I also have a Record regular block plane. If I get the additional blades for the Veritas low angle, is there any need for a regular block plane?
15 replies so far
View LittleShaver's profile
LittleShaver
327 posts in 646 days
#1 posted 06-13-2018 02:11 PM
If you only want one block plane, the low angle is the one to have in my book. Having said that, I must also admit that I have 6 or 8 block planes hanging around. My favorite is the LN rabbit LA block plane.
-- Sawdust Maker
View Rich's profile
Rich
2998 posts in 616 days
#2 posted 06-13-2018 02:40 PM
+1 on the LN rabbet LA. I’ve got an old Record LA that’s a champ in addition to a LN 102 and 101 for detail work.
If you want a standard angle plane that’s different from what you have, consider the E C Emmerich 649P. I did a review for it here.
View Andre's profile
Andre
1888 posts in 1833 days
#3 posted 06-13-2018 03:28 PM
- LittleShaver
The LN rabbit is a low angle but still my favorite plane is the LN brass 102 also low angle and yup, have way to many black planes LOL!
View bandit571's profile
bandit571
20247 posts in 2710 days
#4 posted 06-13-2018 04:27 PM
In the shop…Stanley 60-1/2, Millers Falls 1455, and a 118 all-steel….all are low angle planes.
A few 9-1/2 Stanley block planes, a 9-1/4, a pair of 220s, and a 110….
I use the non-low angle ones for quickly knocking off a corners sharp edge, and places where the low angle planes shouldn’t go….some places with too much dirt and crud. Wonder how many haul one of the Veritas/ L-N blocks around, while shopping rough sawn lumber….a place where an old 110 would feel at home. A few swipes to check for figure….then back into the coat pocket.
( BTW, I have 10 block planes, at last count….) That all steel one has indeed “hopped” off the bench more than once, and onto the concrete floor of the shop….and right back up and right to work, no damage done.
View Slemi's profile
Slemi
117 posts in 1568 days
#5 posted 06-13-2018 05:05 PM
If you want regular angle block plane, just sharpen the blade at different angle. This is easy, since the blade has bevel on the uper side.
cortes
7 posts in 17 days
#6 posted 06-13-2018 06:40 PM
My Record planes are 10-20 years old so not from the period when they made good quality ones as I understand. I also have an old Stanley 220 that was probably my maternal grandfather’s. I’m not letting go of it.
View OSU55's profile
OSU55
1701 posts in 2016 days
#7 posted 06-13-2018 07:04 PM
No. Im not saying one should have only 1 block plane, rather all of them should be LA, and bevels ground at higher angles when needed. I have 6,1 is std angle stanley and 1 is a 45* bd woodie. The steeper angle bp’s rarely get used, LA ones get used all the time. If the record is your only other bp keep it. Mine stay setup for different uses.
cortes
7 posts in 17 days
#8 posted 06-13-2018 07:29 PM
- OSU55
Good point on keeping other block planes set up for specific uses. My regular Record is 9 1/2. Besides cleaning out my plane till, I’m trying to resist buying the Veritas Standard block plane. With the 20 degree bed and a 50 degree blade, I could get a higher angle than I could with the LA version. I don’t know if such an angle would be of any use, however.
View BurlyBob's profile
BurlyBob
5555 posts in 2292 days
#9 posted 06-13-2018 09:24 PM
The Fridge turned me onto a Stanley 60 1/2 a few years back. It’s the only block plane I use anymore. Probably gets way more use than the other 4 dozen+ planes I have in my shop.
View ColonelTravis's profile
ColonelTravis
1802 posts in 1921 days
#10 posted 06-13-2018 10:15 PM
My LN rabbit LA block is the only block I use. Love it to death. I haven’t found a time when I’ve said – man, I wish I had a different block plane. I do have a 9 1/2 and a 60 1/2 and never use them. I might be the weird-o of the group here. Nothing against vintage, got plenty of that in my garage. I think it’s just because I can use the whole blade edge.
It’s up to you if you want more. What the hell, if you want another get another one.
View Don W's profile
Don W
18754 posts in 2594 days
#11 posted 06-13-2018 10:54 PM
if you don’t want planes around that you don’t use, it’s a pretty simple question. “Do I use this plane?”
What you do if your answer is no is up to you.
View JohnChung's profile
JohnChung
410 posts in 2101 days
#12 posted 06-14-2018 06:11 AM
There is a lot of push for one plane rules all.
I came to this conclusion. More the better. I use the LA block plane along with the std block plane.
LA to knock down wood fast until the last mile then I switch to std block plane as not to tearout on wild grain wood.
Not all wood needs 2 planes.
View Derek Cohen's profile
Derek Cohen
380 posts in 3995 days
#13 posted 06-17-2018 01:35 AM
I have a few block planes set up for different tasks: low cutting angle for end grain, high cutting angle for face grain as a small smoother, and small block plane with standard angle for chamfering (sometimes you need smaller to get into spaces which are difficult to reach).
Regads from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View TheFridge's profile
TheFridge
9608 posts in 1513 days
#14 posted 06-17-2018 02:55 AM
Regads from Perth
Derek
- Derek Cohen
Pretty much ditto.
The exception is I have a #1 instead of a standard angle block because I loves me some chipbreakers.
JohnChung
#15 posted 06-20-2018 06:49 AM
Please ignore this entry
