Cutting wood at a 15 degree angle?
Forum topic by neolumber posted 06-12-2018 01:30 PM 526 views 0 times favorited 9 replies Add to Favorites Watch
View neolumber's profile
neolumber
1 post in 129 days
06-12-2018 01:30 PM
I am a newbie.
What kind of inexpensive equipment can I use to cut a 3/4” piece of wood at a 15 degree angle, with pretty good accuracy?
9 replies so far
View Bill_Steele's profile
Bill_Steele
414 posts in 1876 days
#1 posted 06-12-2018 01:51 PM
Miter saw.
View bondogaposis's profile
bondogaposis
4988 posts in 2496 days
#2 posted 06-12-2018 01:57 PM
Hand saw.
-- Bondo Gaposis
View BurlyBob's profile
BurlyBob
5914 posts in 2410 days
#3 posted 06-12-2018 02:00 PM
Table saw. Tip the blade to 75 degrees and have at it. One side will be 15 degrees the other 75 degrees.
View rwe2156's profile
rwe2156
3090 posts in 1625 days
#4 posted 06-12-2018 02:05 PM
You can buy a router pretty cheap at a pawn shop or off craigslist.
You can buy this bit here.
View Fresch's profile
Fresch
321 posts in 2065 days
#5 posted 06-12-2018 02:18 PM
Wait till January?
View bandit571's profile
bandit571
21282 posts in 2828 days
#6 posted 06-12-2018 02:24 PM
Works for me….
View LesB's profile
LesB
1817 posts in 3588 days
#7 posted 06-12-2018 11:59 PM
You question leaves some unexplained perimeters. The wood is 3/4” by what and I’m not sure what “pretty good accuracy” is.
Also do you want a power tool or a hand tool. With a little practice just a protractor and simple hand saw saw is as inexpensive as you can get (probably $20 to $30) and with care you can get very close.
For inexpensive power equipment, I would recommend finding a used compound miter say on Craig’s list or E-bay.
House framers can be off a degree or two but fine furniture need to be made exactly.
re2156 is confused between a cut and a bevel.
-- Les B, Oregon
View jonah's profile
jonah
1841 posts in 3443 days
#8 posted 06-13-2018 01:53 AM
Which part of the board are you trying to cut at an angle? How big is it? If it’s the long side of a 2ft x 6inch x 3/4 inch board, for instance, you’ll need a table saw or a circular saw. If its the short side of the same board, you can do it with a hand saw, a miter saw, or a table saw.
View AlaskaGuy's profile
AlaskaGuy
4496 posts in 2454 days
#9 posted 06-13-2018 01:59 AM
I’m wondering if he’s cut a miter across the face of the board or on the edge like cutting a bevel.
A miter cut refers to an angled cut on the face of two structures, which will be joined to make a corner called the miter joint. A bevel cut refers to an angled cut along the edge or end of the material. Miter cuts are made by pushing the flat on the table at an angle to the blade.
