The Correct Hinges
Forum topic by tjbisme posted 06-11-2018 06:56 PM 492 views 0 times favorited 6 replies Add to Favorites Watch
View tjbisme's profile
tjbisme
26 posts in 564 days
06-11-2018 06:56 PM
Topic tags/keywords: hinges
I’m wondering if someone can point me in the right direction for some hinges to finish a bench. The bench has been built into the wall and we added a spacing piece on top where the lid sits, so when the lid is opened all the way, it can rest against the wall. What would be the best type of hinges to use for this setup? Essentially the lid will meet up edge to edge with the spacing board. We’d also like to have the lid be soft closing so it doesn’t come slamming down.
Any recommendations on what the best route would be will be much appreciated.
Thank You,
Trevor
View DS's profile
DS
3030 posts in 2618 days
#1 posted 06-11-2018 07:05 PM
Usually, I would use a piano hinge and a lid stay.
View Dmitriy_S's profile
Dmitriy_S
10 posts in 186 days
#2 posted 06-11-2018 07:42 PM
Invisible hinge + lid stay.
https://www.soss.com/invisible-hinge.html
tjbisme
#3 posted 06-11-2018 08:47 PM
I think the piano hinge with lid stay might be the ticket. However, I believe we want to keep the hinge hidden. The piano hinge spine would be sticking up through the joined edges.
I don’t think the hidden hinges would work because of the two boards would be joined together, along the edge.
Thank you,
Trevor
View oldnovice's profile
oldnovice
7321 posts in 3565 days
#4 posted 06-12-2018 05:50 PM
The piano hinge is an easy solution while the SOSS hinge is more difficult to install it is, in my opinion, more elegant.
View DS's profile
DS
#5 posted 06-12-2018 06:48 PM
If you wanted to use a 35mm European concealed hinge, you could use a blind corner hinge.
You would just need to be sure the lid is supported by something other than the hinge when it is closed. (25lbs per pair is the load limit)
View jdh122's profile
jdh122
1052 posts in 3015 days
#6 posted 06-12-2018 06:51 PM
A hinge like this one?
http://www.leevalley.com/us/Hardware/page.aspx?p=40647&cat=3,41427
-- Jeremy, in the Acadian forests
