Woodtek 900881 chisel mortiser
Forum topic by RichBolduc posted 06-11-2018 02:21 PM 703 views 0 times favorited 7 replies Add to Favorites Watch
View RichBolduc's profile
RichBolduc
583 posts in 357 days
06-11-2018 02:21 PM
So I apparently bid on and won a Woodtek 900881 chisel mortiser. It’s a 1HP model. I can’t find any documentation on it though it seems. Anyone have any insight on it or know where I can find some info on it?
Thanks, Rich
7 replies so far
View Loren's profile
10477 posts in 3888 days
#1 posted 06-11-2018 02:48 PM
Woodtek is a Woodworkers Supply house brand.
View GR8HUNTER's profile
GR8HUNTER
5399 posts in 953 days
#2 posted 06-11-2018 03:29 PM
RichBolduc
#3 posted 06-11-2018 03:30 PM
That’s only a 1/2 power one… Not sure what the differences will be. I also know nothing about the bits to get. Are all bits universal like on a drill press?
Rich
#4 posted 06-11-2018 04:23 PM
The square chisels have a shank size and you can
only use ones you have the bushings for.
The drill inside chucks into a drill chuck. My hollow
mortiser was like that anyway.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#5 posted 06-11-2018 10:21 PM
The link above says it takes 5/8” shank chisels. That’s a common size, my Delta mortiser takes 5/8” shanks.
My Jet floor mortiser accepts either 5/8” or 3/4” shanks. If you buy a set with 5/8” shank you should be fine.
You can confirm this by measuring the bushing that accepts the bits.
Have fun.
RichBolduc
#6 posted 06-12-2018 03:01 PM
Thanks. Any set recommendations?
Rich
The link above says it takes 5/8” shank chisels. That s a common size, my Delta mortiser takes 5/8” shanks.
Have fun.
- pintodeluxe
pintodeluxe
#7 posted 06-12-2018 03:15 PM
I have used Delta, Jet, Grizzly and Woodstock brand chisels. They all cut about the same. Never as shiny as the marketing pictures would have you believe, and all seem to need honing and sharpening. Oddly, the only one that ever failed was the most expensive Jet brand. Well, I’ve had several 1/4” drill bits break over time but the square chisels are pretty sturdy. This one Jet chisel curled under like a bobby pin. Then again I have other Jet chisels that have really lasted, so maybe it was a fluke.
I get the Woodstock ones, but the low cost models look very similar from one brand to the next. A lot of the sets I see advertised on Amazon have 3/4” shanks though.
