Ridgid r4510 Table Saw / Forrest Woodworker II blade
Forum topic by handystanley posted 06-18-2011 10:36 PM 2417 views 0 times favorited 4 replies Add to Favorites Watch
View handystanley's profile
handystanley
169 posts in 2782 days
06-18-2011 10:36 PM
Topic tags/keywords: r4510 ridgid forrest woodworker tablesaw
As mentioned in the title I have a Ridgid 4510 table saw and would like to order a Forrest Woodworker II blade for it. I noticed in the Rockler catalog that there are two kerf’s available….a .093 and a .125. Does anyone see a problem with the .093 kerf? A smaller kerf is always better…right?
Thanks as always!
Stan
-- "Projects beget projects and projects beget the need to buy new tools and that is what the cycle of life is all about." Stan Pearse, Novato, CA
View StephenO's profile
StephenO
44 posts in 2415 days
#1 posted 06-18-2011 10:40 PM
You actually will pretty much need to go with the thin kerf for a portable saw (that’s what they come with, and splitters/riving knives on them are for the thinner kerf), the full kerf will bog down the motor.
-- -Steve, Seattle
View syenefarmer's profile
syenefarmer
481 posts in 2950 days
#2 posted 06-18-2011 11:39 PM
Either kerf should work with your saw. It’s true that the thin kerf will be easier for your saw’s motor to spin but if your saw is properly aligned you shouldn’t have any trouble using a full kerf blade either.
EDIT: Ooops, misread your model number. For that saw, you should definitely go with the thin kerf blade. Sorry about that.
View ferstler's profile
ferstler
342 posts in 3389 days
#3 posted 06-19-2011 12:05 AM
The riving knife with that saw is better suited to the thin-kerf blade.
I did a review and modification-idea post on that saw at:
http://lumberjocks.com/reviews/2006
You might enjoy it.
Howard Ferstler
View knotscott's profile
knotscott
7817 posts in 3245 days
#4 posted 06-19-2011 12:17 AM
A smaller kerf isn’t always “better”, but if all else is equal it will always put less strain on your saw’s motor, which will be most noticeable when ripping thicker materials. It should help the motor last longer in the long run.
