Is 1/2" ok for drawer fronts?
Forum topic by Cory posted 06-18-2011 09:59 PM 1109 views 0 times favorited 3 replies Add to Favorites Watch
View Cory's profile
Cory
760 posts in 3388 days
06-18-2011 09:59 PM
I’m in the homestretch of a dresser/changing table project and I’ve got a quick question for you experts. I’m using solid cherry for some false fronts on the drawers. The drawer boxes themselves are solid 1/2” cherry with 1/4” ply bottom. I’d like to use continuous grain all the way through the drawer fronts, so I’ve selected some wide boards (about 10”). The problem is that after milling them 4 square, I can only get about a 1/2” inch thickness. Will that stand up to thousands of openings and closings? Should I bite the bullet and buy some 5/4 boards to surface down to a full 3/4”?
Thanks for the help.
Cory
-- The secret to getting ahead is getting started.
3 replies so far
View tenontim's profile
tenontim
2131 posts in 3713 days
#1 posted 06-18-2011 10:17 PM
When I build drawers, using this method. 1/2” all the way. 3/4” would be alright if you’re cutting the dovetails into them, but the 1/2” will work fine for this method.
View richgreer's profile
richgreer
4541 posts in 3043 days
#2 posted 06-18-2011 10:46 PM
1/2” is fine.
View verdesardog's profile
verdesardog
159 posts in 2580 days
#3 posted 06-18-2011 11:09 PM
It depends on the style of cabinets. Are the doors inset or overlay? If overlay the drawer fronts need to be the same thickness as the doors.
-- .. heyoka ..
