Making a circular wishing well / Flute & Bead Bits
Forum topic by chrisstef posted 06-18-2011 08:25 PM 2462 views 0 times favorited 4 replies Add to Favorites Watch
View chrisstef's profile
chrisstef
17562 posts in 3090 days
06-18-2011 08:25 PM
At the antique sale this morning the wife and i purchased an old well pump. She would liike me to build a small circular base for it, lets say 2’ in diameter (actual measurments not known). Now im sure that if i do my math right i can calculate the angle of each cut to make it kinda circular, but, i was curious if anyone had tried using a flute and bead bit. Would it be easier to rout the edges with the F&B bit or cut angles on the table saw? My guess is that the router bits will produce a more flexible and circular piece? Do i Glue it, Nail it or band it?
FYI:
I have a much more accurate router setup than i do an accurate tablesaw.
This will be non-functional and outside covering our well head.
Materials are undertermined but likely cedar.
View Sodabowski's profile
Sodabowski
2374 posts in 2916 days
#1 posted 06-18-2011 11:38 PM
Uh, I don’t get it, what do you exactly want to make? maybe a drawing would be helpful ^^’
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
chrisstef
#2 posted 06-19-2011 12:00 AM
Id like it to be 1”x 4” vertical slats arranged in a circle about 2’ in diameter … basically an upside down bucket that an antique hand powered water pump would sit upon.
http://mainebucket.com/wood-products/cedar-planter-tubs/18-x-14-cedar-tubs/prod_142.html
Somethin like this but i would use it upside down and mount the pump atop.
The flute and bead bit is typically used for making strip canoes so im not real sure if it would work.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_flute.html
View shipwright's profile
shipwright
8031 posts in 2881 days
#3 posted 06-19-2011 02:48 AM
I’ve used bead and cove like those in boat building and they work very well.
Just be aware that there is a limit to the angle you can take them to. You may end up with a lot of quite thin staves.
Have you considered bird’s mouth joint. Very easy to make on a table saw, self aligning and easy to clamp..
chrisstef
#4 posted 06-19-2011 03:23 AM
Thanks for the info Paul ill definately look into the birds mouth. I dont have a final design yet so everything is worth research at this point.
