Removing 18 gauge brads from Oak
Forum topic by Douglas posted 06-18-2011 06:10 AM 6220 views 0 times favorited 20 replies Add to Favorites Watch
View Douglas's profile
Douglas
424 posts in 2795 days
06-18-2011 06:10 AM
Topic tags/keywords: question
I’m trying to save about eight pieces of red oak that were pinned together with 18 gauge brads in door frames. Those little nails break off 50% of the time when trying to pull them with pliers. They’re too soft to hammer the heads out, not that there is very much in the way of heads on those. Any tips or suggestions for the best way to get these out, especially the ones that are broken off?
-- Douglas in Chicago - https://dcwwoodworks.com
20 replies so far
View learnin2do's profile
learnin2do
889 posts in 3087 days
#1 posted 06-18-2011 06:34 AM
The pliar/hammer tool from …oh, wait…I don’t think they have that store anymore -sharper image, but I think they sell them other places – that is the only tool I have ever had luck doing that with. – I guess the angle is right or something. – it is awesome for that and carpet removal!
-- ~christine @ used2btrees
View philip marcou's profile
philip marcou
265 posts in 2832 days
#2 posted 06-18-2011 06:38 AM
As you say, they usually break off if you try to pull them-if there is enough to pull on. I suggest you cut them near to flush then flush them with a file which will give a nail punch something to centre on then just punch them below the surface: since it is Oak you can fill the holes with slivers of Oak which will look entirely natural.
I have recently done just that with some reclaimed timber and saved much time and frustration.
View David 's profile
David
81 posts in 2869 days
#3 posted 06-18-2011 06:41 AM
try wetting the wood real good to make it swell a little. put vice grips on brad ans twist just a little back and forth using very little pressure. keep the wood wet. get a very large drink of your choice it will take a while. It took me a day and half to get a broken bolt out of a water jacket on my old cummins engine one time. It cost a case of beer but saved me about $3000.00 for a used block. soaking wood is how i put marbles in my bull whip handles.
good luck.
-- David, Center,Texas
View BobTheFish's profile
BobTheFish
361 posts in 2787 days
#4 posted 06-18-2011 01:17 PM
I agree with the hammer down till flush method, and use another nail slightly smaller or about the same size as a pin set to knock them out. Even if you use a same size nail, the act of hammering down (combined with the fact that you’ll be using stiffer nails, most likely), should change the hole enough that the new nails would be easier to pull out..
View saddletramp's profile
saddletramp
1180 posts in 2874 days
#5 posted 06-18-2011 01:37 PM
I have one of these: http://www.nailextractor.com/ and although it’s not perfect, I’ve had pretty good luck with it. Oh, it always seems to work better if you start from the back and pull the nail
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
View Sawkerf's profile
Sawkerf
1730 posts in 3304 days
#6 posted 06-18-2011 04:17 PM
Pulling brads out of hardwood will almost always be an exercise in futility – they have an incredible “grip”.
I either cut them away, or clip them flush and use a nail set to drive them below the surface so I can use a filler to hide them.
If you cut them away, be careful. Cutting them with a carbide blade doesn’t seem to be a problem, but I doubt if a regular steel blade will do very well.
View rsdowdy's profile
rsdowdy
105 posts in 3431 days
#7 posted 06-18-2011 05:31 PM
Thats a great question! I have alot of pallet norwegian spurce (I guess spruce is spruce) and it has small nails that need to be removed. Seeing that I was just going to use this wood to pratice skills with I was just going to chomp off the ends and nailed areas, but, I’d like to see what answers people come up with!
Good question, thanks for asking it and thank everyone who answers!
Royal
View rmoore's profile
rmoore
325 posts in 2870 days
#8 posted 06-18-2011 05:50 PM
Woodcraft sells an extractor for screws. The smallest is 1/4 inch. You cut out around the screw/ nail then fill the hole. http://www.woodcraft.com/Product/2000983/2009/Screw-Extractor-14.aspx
-- The more I learn, the more I realize I don't know. Ron, Crossville Tn
View BlankMan's profile
BlankMan
1490 posts in 3588 days
#9 posted 06-18-2011 07:14 PM
Been there, done this. Many times.
I use tempered hardboard on all my bench tops so that when it gets used up, damaged I replace it and the bench looks new again. I hold the hardboard in place with brads, usually more then I need to. When I rip the hardboard off I have to remove the brads.
As long as the brads are sticking up a bit I can get them out with a small diagonal cutter (real small cutter), better know as a wire cutter. If the brad has a little head on it you can close the cutter on it so that you pull on the head using the tip of the cutter as the fulcrum (lever) point. If there is no head I carefully squeeze the cutter biting into the brad being real careful not to cut through it but enough to grab it, then again, lever it out.
Looks like yours are sticking out enough to try this.
-- -Curt, Milwaukee, WI
BlankMan
#10 posted 06-18-2011 07:35 PM
Here’s what I consider small diagonal cutters.
saddletramp
#11 posted 06-18-2011 08:09 PM
Curt, that is just what the extractor ( http://www.nailextractor.com/ ) does but with less damage to the surrounding wood.
rsdowdy
#12 posted 06-18-2011 08:14 PM
I like the looks of that nail extractor Bob. Anyone else have good/bad experience with that tool? I expect alot of my hardwood will be reclaimed wood at first so am curious about these different removal tools/efforts. Would hate to mess us a set of knives trying to save 1.00 worth of wood.
Royal
BlankMan
#13 posted 06-18-2011 08:56 PM
Bob, will it do brads? I always thought those were for bigger nails and wouldn’t grip something as small as brads.
Just checked out the link, guess it does brads.
I always wanted one of those for bigger nails after seeing something similar used by Norm and on other shows but could not find any locally. Thanks for the link! I saw it before and looked at it but didn’t read the part that said brads. Not priced too bad either.
saddletramp
#14 posted 06-18-2011 09:06 PM
It works pretty good on brad, pulls them right through the wood, head and all …... most of the time. Sometimes it will break them off in the wood.
View William's profile
William
9950 posts in 3078 days
#15 posted 06-18-2011 09:10 PM
Catfish skinning pliers. Do an internet search and you can see what I’m talking about if you don’t know what they are. Don’t grip the brad and just go one way though. Get ahold of it and kind of rock the pliers back and forth on their ends. I get I guess about 99% out this way. I have yet to find a way to get them all out all the time.
Go here to see a pair of catfish skinning pliers.
If you are planning on doing this much and also are a fisherman, you need more than one pair. Pulling nails with them over time renders them useless for skinning catfish with them. Besides that, I really don’t want catfish smell on my wood work.
