Jigsaws: Regular vs Barrel Grip
Forum topic by jstewart posted 607 days ago 797 views 0 times favorited 11 replies Add to Favorites Watch
View jstewart's profile
jstewart
141 posts in 986 days
607 days ago
Topic tags/keywords: jigsaw advice barrel grip question
Does anybody have any pros and cons of the two styles of jigsaws. I was planning on buying a barrel grip jigsaw because I liked the idea of having my hand a little closer to the wood, for a little extra control. I was warned that the barrel grip ones can feel rather hot since your hand is wrapped around the motor. Are there any other things I should be thinking about?
-- Joshua, Olathe, Kansas
View GaryK's profile (online now)
GaryK
9528 posts in 883 days
607 days ago
With a top grip you use a lot more wrist action and you’re looking down on your cut.
With a barrel it’s more upper body movement to control it and you’re not really looking down
on your cut in a natural position. More of an off the the side look.
View Kevin Violette's profile
Kevin Violette
214 posts in 758 days
607 days ago
I owned a bosch barrel grip and didn’t like it due to the switch is on the side where my thumb was and I found it awkward to turn the unit off and on smoothly. I now have a dewalt regular grip with a trigger switch at your finger and I find it easier for me anyways to turn the unit on and off.
-- Kevin -- (http://www.furniturebykevin.com)
View gunner's profile
gunner
11 posts in 659 days
607 days ago
I’ve used a barrel grip Bosch for upwards of 20 years building boats with lots of cutting of thick fiberglass. I don’t think you could torture a saw any more. I think the barrel grip offers much better control, the top grip feels very awkward to me. I seem to remember some slight heat issues under very heavy load cutting fiberglass and steel a few times, but never in wood. I would never own anything else, barrel grip all the way.
20668 posts in 717 days
607 days ago
I tend to agree with Gary’s comment. I have only used top grip saws. I guess it is what you get used to. But to me the top grip is a more natural cut and less strenuous to operate.
View mrtrim's profile
mrtrim
1698 posts in 775 days
607 days ago
im a barrel handle guy ! i use mine a lot to cope large crown moulding it takes a lot of control to do this and the d handle saws dont get it done for me . ive never had a heat issue . my 2 scents
View DGunn's profile
DGunn
49 posts in 649 days
607 days ago
I have only used a top grip so I can’t compare the two. My advice would be to go to Lowes or somewhere like that and put your hands on each type. Then maybe you will have a better idea of what you prefer.
View rikkor's profile
rikkor
11335 posts in 769 days
606 days ago
I prefer the top grip. That is just because that is all I have used. I agree that the heat issue might be a problem, but probably not in a higher end model.
View motthunter's profile
motthunter
2079 posts in 694 days
606 days ago
barrel is my favorite. like most tool questions, it comes down to a question of personal preference
-- making sawdust....
View ToddO's profile
ToddO
78 posts in 718 days
606 days ago
I own the Craftsman jig saw that allows you to use it either as a barrel or top grip. I find that for scroll type work the top grip is better for me. But for straight cuts, cuts with a larger radius, or for cuts where you need to extend your reach, (i.e. cutting a pattern out of a sheet of ply) the barrel grip is more comfortable. I think it depends on the work you’re doing. BTW’s you might want to look at the Craftsman, it’s a nice saw.
-- Todd, Richfield MN
View Dadoo's profile
Dadoo
1723 posts in 885 days
606 days ago
I fully agree with ToddO and own the same saw. Using the barrel grip does afford better control but sometimes the job calls for a handle. It’s a nice feature that Craftsman has incorporated into theirs, giving you the option of both.
View Mat's profile
Mat
9 posts in 629 days
606 days ago
I have the same jig saw as todd0 and daddo. The top grip goes on and off easily and allows you to choose what will work best for what you’re tring to do. I love mine! Craftsman Professional Laser Trac™ 2-in-1 Jig saw with LED
