HELP with BN125A
Forum topic by GR8HUNTER posted 06-10-2018 12:16 AM 608 views 0 times favorited 16 replies Add to Favorites Watch
View GR8HUNTER's profile (online now)
GR8HUNTER
5365 posts in 947 days
06-10-2018 12:16 AM
Topic tags/keywords: porter cable bn 125a nailer
I lost my little pin and bushing ….. has the ever happen to you ? … if so how did you fix it …. I think for bushing I could just use small o -ring … I really dont feel like paying $15.00 for this fix :<((
16 replies so far
View hairy's profile
hairy
2783 posts in 3766 days
#1 posted 06-10-2018 01:58 AM
That link doesn’t show anything.
-- My reality check bounced...
GR8HUNTER
#2 posted 06-10-2018 02:05 AM
weird seems to work for me UMMM :<((
View 000's profile
000
2859 posts in 1134 days
#3 posted 06-10-2018 02:09 AM
Works for you because it is in Your shopping cart?
Place a link to the part on the parts page.
GR8HUNTER
#4 posted 06-10-2018 02:41 AM
sorry try THIS :<))
https://www.ereplacementparts.com/images/porter_cable/BN125A.pdf
PART #403 AND #213
View MrUnix's profile
MrUnix
7102 posts in 2433 days
#5 posted 06-10-2018 02:57 AM
You could easily make something that would work for a few pennies. Cotter pin comes to mind. Heck, even a piece of coat hanger with the ends bent to keep it in place. Or find a similar diameter metal rod, then cut and file a groove on each end and use a couple of c-clips. You might get lucky and find a suitable sized pivot pin at your local ACE hardware store or in the specialty bins at the BORG. I can think of a zillion ways to do it – just depends on what you happen to have laying around and how much you want to spend.
View Lazyman's profile (online now)
Lazyman
2701 posts in 1622 days
#6 posted 06-10-2018 02:50 PM
If you have a good hardware store nearby with a good selection (better than HD and Lowes anyway), they may have a comparable pin you can use or modify or you could simply try grinding the threads off a screw until it fits.
Edit: Might be slightly cheaper at mmtoolparts.com (never used them but they claim to be an authorized dealer).
View John Smith's profile
John Smith
1538 posts in 397 days
#7 posted 06-10-2018 03:40 PM
I would cut a nail to size, slip on a small washer, wrap string around the end
and apply a drop or two of CA glue.
while the CA glue is drying ~ I would go to the Big Box Store and buy ANOTHER one !!!
-- I started out with nothing in life ~ and still have most of it left.
GR8HUNTER
#8 posted 06-11-2018 12:40 AM
- Lazyman
no mmtoolparts.com does not have them but thanks Nathan :<))
View 000's profile
000
#9 posted 06-11-2018 12:50 AM
Probably should be able to find a machine screw with a nut. (double nut if needed)
Lazyman
#10 posted 06-11-2018 01:40 AM
Hmm, I wonder if I put the last one of each in the shopping cart so it wasn’t available for you? It came to $ 12.56 with shipping to TX. I’ve cleared my cart now so try it again
- Lazyman
- GR8HUNTER
View HokieKen's profile
HokieKen
7504 posts in 1373 days
#11 posted 06-11-2018 08:24 PM
Sorry Tony. You just have to buy a new nailgun.
;-P
-- Kenny, SW VA, Go Hokies!!!
GR8HUNTER
#12 posted 06-11-2018 11:01 PM
UPDATE ….all fixed up …. for some reason I was making this harder then it needed to be …. I just found a nail the same size slide it in and gave it a little bend with pliers …… thanks all for guiding me into this very easy fix :<)))))))
John Smith
#13 posted 06-12-2018 11:55 AM
I think there are not too many of us left that were raised either on, near,
or in the atmosphere of farmland or with parents, family members or friends
that came up through the Great Depression and Hard Times.
where you took care of everything yourself. more often as not, malfunctioning
or broken tools and machinery was fixed with an old bolt, a bent nail and baling wire.
(the Millennials will have to google baling wire to see what it is).
their motto was: use it up, fix it up, make it do – or do without.
I miss those people.
good job on fixing your nail gun [the Old School way].
GR8HUNTER
#14 posted 06-12-2018 02:33 PM
thank you John …. some times I will go to ebay and just buy the whole tool …. cheaper then parts … then I will have extra parts … plus I have a cabinet in shop overfull with older machines …you never know some day :<))
View htl's profile
htl
4317 posts in 1394 days
#15 posted 06-13-2018 11:07 PM
I moved last year and the house sold fast which is great but it put the push on us to get moved out so I got rid of a lot a great junk that I sure could use now, but no I have to go buy a nut or washer that a year ago I had a ton of. LOL
Sad but true.
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
