Is concave bent lamination possible?
Forum topic by lots2learn posted 06-17-2011 05:13 AM 3446 views 2 times favorited 15 replies Add to Favorites Watch
View lots2learn's profile
lots2learn
31 posts in 3237 days
06-17-2011 05:13 AM
I’m dreaming up my next project and have a design element in my head. It’s a concave shape. What I mean by concave is, it’s like the inside of a bowl. It will be on a much larger scale, like a set of drawer fronts or the side of a table. Not deep at all though, just the subtle shape. It looks to be a large bent lamination project. While I’ve used bent lamination on a few pieces the additional bend (like folding a piece of paper into a tube and then bending it) has me perplexed. I can’t afford a very thick piece of wood to carve the shape out of (although the form will be pricey I’m sure). The idea is to bend laminate some bending ply, or homemade poplar laminate and then veneer the outer shell. I was thinking of maybe taking one or two plys at a time, wetting or steaming it somehow and trying to work it around a form before putting it in a veneer bag. Do you guys think that will work? Impossible? Any other ideas?
-- http://www.bolanoswoodworks.com; http://www.facebook.com/bolanoswoodworks
15 replies so far
View Loren's profile
10476 posts in 3676 days
#1 posted 06-17-2011 05:21 AM
Concave, convex. It can work. It’s done for backs and fronts of
low-end archtop guitars.
At some point there’s a point of no return if bending in more
than one axis where your material will fall apart.
View David Kirtley's profile
David Kirtley
1286 posts in 3026 days
#2 posted 06-17-2011 01:21 PM
Cold molded boats, salad bowls, and skateboard decks are made that way too.
View saddletramp's profile
saddletramp
1180 posts in 2666 days
#3 posted 06-17-2011 01:45 PM
Instead of trying to force your laminations into a concave form, you could do your form from the other side allowing you to do a convex lamination.
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
View docholladay's profile
docholladay
1287 posts in 3087 days
#4 posted 06-17-2011 02:15 PM
I haven’t tried, but would say it should be doable if the curvature is gentle enough. If too much of a bend, probably not. I would suggest that the veneer be wet to make it more flexible when applied. I also would recommedn vacuum bag veneering. Can’t think of any other way that you could clamp it for solid bonding.
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View BobTheFish's profile
BobTheFish
361 posts in 2580 days
#5 posted 06-17-2011 03:31 PM
View BarbS's profile
BarbS
2434 posts in 4113 days
#6 posted 06-17-2011 04:20 PM
Or you could try Kerf-bending. Lots of links to it on Google:
http://tinyurl.com/3ncx23j
-- http://barbsid.blogspot.com/
View Gregn's profile
Gregn
1642 posts in 3011 days
#7 posted 06-18-2011 05:08 AM
Are looking to do something like this?
http://www.wikihow.com/Bend-Wood
View sras's profile
sras
4812 posts in 3157 days
#8 posted 06-18-2011 04:18 PM
Cool idea – you could end up with an impressive shape. If I were attempting this, I would lay strips on a form. I have done this with a strip built kayak. The form can be built up of a set of cross sections of 1/2-3/4” plywood spaced every foot or so.
If the curvature is subtle enough, you could use some fairly wide strips. Maybe taper them at the ends – wider in the middle. I would try to use the thickest strips I could as well. The kayak used 1/4” thick strips, but if the shape is not too aggressive, I would see if 1/2” or greater would work. The kayak has fiberglass on each side, but I would think thicker wood can give a strong enough piece.
The technique I used for the kayak was to bevel the edges of each strip to get a tight fit and create a nearly invisible joint. I used a small hand plane and a LOT of test fits for each strip.
Once the shape is built up, a bit of hand shaping will create a smooth form.
If you are set on using veneer, maybe the strip built technique would be a way to get a base structure and then try to form veneer as a top layer.
View sras's profile
sras
#9 posted 06-18-2011 04:22 PM
Here is a blog on the technique for kayak building. It shows you what I mean about the form setup and the rolling bevel for the edge joints.
Be careful! You read too much and you might get sucked into building a kayak!
View rmoore's profile
rmoore
325 posts in 2663 days
#10 posted 06-18-2011 05:32 PM
I just saw this posted. http://lumberjocks.com/topics/27829 Hope it helps.
-- The more I learn, the more I realize I don't know. Ron, Crossville Tn
View shipwright's profile
shipwright
7992 posts in 2826 days
#11 posted 06-18-2011 05:35 PM
Steve is right. You could do it with narrow strips, like strip planking a canoe.
If it were me, I would shape the pieces (each will be narrower at the ends than the middle for a bowl shape) according to the shape you’re trying to achieve. Lay up about three layers of thin stock on opposing diagonals.
You can make any shape you can imagine that way. As David said, look up cold molded boat construction.
View DLCW's profile
DLCW
530 posts in 2682 days
#12 posted 06-20-2011 05:27 AM
Here is a bathroom vanity I did several years ago using bent form lamination. You take a board, resaw it into 1/16” or 3/32” veneer and glue the veneers back together using a bending form. I built my bending forms from 3/4” MDF. You create two sides of the form and with that you can get concave or convex.
The drawer faces in the vanity are all bent form solid wood. The doors on the quarter round medicine cabinets are coopered and smoothed inside and out using a grinder, scraper and sandpaper.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
lots2learn
#13 posted 06-21-2011 05:18 AM
Thank you everyone for your input. It never ceases to amaze me how many people go out of their way to be helpful around here. I’m afraid that I have a creative block or something, but you have all given me options to think about. Once I have my design hatched out I’m definitely going to incorporate some of these suggestions.
View Radiuswoodguy's profile
Radiuswoodguy
33 posts in 2956 days
#14 posted 03-02-2012 03:44 AM
There are many ways to accomplish your goal. Years of bending taught me keep it simple, Vacuum is wonderful and has its limitations; your lamination may be best done with strap clamps the wide ones are cheap and pack tork. The skill comes from producing the stock one needs to clamp, if you got that part “no worries”. A good compatible form and good glue proper cover sheet. There are tricks for compound bending’s. Send me an email with drawing and approx. radius I may be able to lead in the right direction Clamping is all about pressure lots of ways to accomplish that!
-- Radiuswoodguy
Radiuswoodguy
#15 posted 03-02-2012 04:00 AM
There are many ways to accomplish your goal. Years of bending taught me keep it simple, Vacuum is wonderful and has its limitations; your lamination may be best done with strap clamps the wide ones are cheap and pack tork. The skill comes from producing the stock one needs to clamp, if you got that part “no worries”. A good compatible form and good glue proper cover sheet. There are tricks for compound bending’s. Send me an email with drawing and approx. radius I may be able to lead in the right direction Clamping is all about pressure lots of ways to accomplish that! Radiuswoodguy.com
-- Radiuswoodguy
