Bandsaw box sanding question
Forum topic by WoodworkingGeek posted 702 days ago 1311 views 1 time favorited 5 replies Add to Favorites Watch
View WoodworkingGeek's profile
WoodworkingGeek
179 posts in 858 days
702 days ago
Topic tags/keywords: question
Not long ago I bought a 12’’ band saw and now I want to make some band saw boxes with the saw. I made a band saw box before and had trouble with saw marks. I tried to sand but after that the fit was not so good. Another thing any tips on finishes, I see these band saw boxes on LJ and I don’t know how they get such a finish!! Give me your advice please!!
Thanks for the help!!
Matthew
5 replies so far
View Loren's profile
4870 posts in 1813 days
#1 posted 702 days ago
Use cool blocks jammed up against the blade so the blade is
captive inside the blocks. Use a 1/8” blade.
View gfadvm's profile
gfadvm
6611 posts in 856 days
#2 posted 702 days ago
Probably shouldnt admit this but I do very minimal sanding on the inside of the box or drawers as I find it just screws up the fit.The outside is sanded to 150 grit and finish is usually 10 to 15 coats of Spar/mineral spirits [3:1] wiped on OR if Im less motivated: numerous coats of spray can lacquer. Light rub with grey Scotch brite between coats if any raised grain/roughening appear. Hope this helps. ps: 2 or 3 coats of hand buffed Renissance wax after finish is FULLY cured.
View blackcherry's profile
blackcherry
2900 posts in 1989 days
#3 posted 702 days ago
I would love to give advise , but one of the best books on BS boxes is by Lois Ventura. You could check it out at your local library and be well off on your way to becoming a BS artist. Seriously it by far the best reference on this subject.
WoodworkingGeek
#4 posted 701 days ago
Thanks for your advice!!
I never thought of getting a book on the subject so thanks for telling me about it! I’ll be buying it on amazon.
Thanks again
Matthew
View Roger's profile
Roger
9191 posts in 970 days
#5 posted 701 days ago
half.com is also a great place for books n such
