Formaldehyde free carpenter glue
Forum topic by Katcore1 posted 06-06-2018 01:49 PM 642 views 0 times favorited 12 replies Add to Favorites Watch
View Katcore1's profile
Katcore1
3 posts in 232 days
06-06-2018 01:49 PM
Topic tags/keywords: glue
Hello,
I have a project that requires formaldehyde free plywood and and we are thinking of making the plywood ourselves. Does anyone know what kind of carpenter glue is formaldehyde free.
Thanks
12 replies so far
View RobHannon's profile
RobHannon
222 posts in 772 days
#1 posted 06-06-2018 02:02 PM
Purebond Plywood at Home Depot is formaldehyde free. I would imagine the other suppliers also have a formaldehyde free plywood.
View John Smith's profile
John Smith
1555 posts in 404 days
#2 posted 06-06-2018 03:19 PM
”we are thinking of making the plywood ourselves.
Does anyone know what kind of carpenter glue is formaldehyde free.”
Thanks, Katcore1
how big is your project??
what size do you think you will make??
what wood will you be using for the internal plys??
how many sheets are you thinking of making??
what thickness do you need to make??
[ just out of curiosity ]
-- I started out with nothing in life ~ and still have most of it left.
Katcore1
3 posts in 232 days
#3 posted 06-06-2018 03:34 PM
8 ea, 16’ long doors that have a 3/8 A/B plywood skin
John Smith
#4 posted 06-06-2018 04:44 PM
I guess just to clarify – - – you are making laminated doors? interior or exterior? how wide?
will they be hollow core or solid plywood? hang on hinges, hang on rails or interior pocket doors?
are you going to purchase the plywood skins from a store? or make them yourself.
trying to find formaldehyde free wood glue is very understandable.
we just don’t understand the rest of the project you are getting into.
(and why do you need formaldehyde free in the project).
not knowing how wide or thick your doors will be, and their use, is still a question.
View Loren's profile
10477 posts in 3890 days
#5 posted 06-06-2018 05:24 PM
John Smith
#6 posted 06-06-2018 06:21 PM
just out of curiosity, I took one minute out of my day and called TiteBond.
the technical service rep said that Franklin Titebond II and III do not
contain formaldehyde. and he further added, they do not use formaldehyde
in ANY of their products what-so-ever.
so – you can feel safe using any TiteBond product on any of your projects.
Katcore1
3 posts in 232 days
#7 posted 06-06-2018 06:41 PM
Thanks for the information, Loren and John Smith
View Magnum's profile
Magnum
10935 posts in 3275 days
#8 posted 06-07-2018 12:41 AM
DOUBLE POST! >>>> AGAIN!!!!
Good Information John! Thanks!
Rick
- John Smith
-- Made In Ontario, CANADA
Magnum
#9 posted 06-07-2018 12:45 AM
- John Smith
Thanks John. Good Information!
Rick
Magnum
#10 posted 06-07-2018 12:48 AM
- RobHannon
I’d go with Rob’s suggestion. Why would you want to spend all of that TIME just to make Plywood?
Rick
#11 posted 06-07-2018 12:54 AM
It sounds to me like the project may require 16’
long veneers on the face. It sounds like
a job for a giant millwork shop, but if the
client has the budget…
8’ cores can be joined for veneering if that’s
an issue. Done right and properly supported
I don’t think the joint will show through the
veneer face. For a giant slab door I might have
a reputable shop weld up a flat steel frame,
screw substrate to it and vacuum bag it for
veneering.
RobHannon
#12 posted 06-08-2018 02:13 PM
8 ea, 16 long doors that have a 3/8 A/B plywood skin
- Katcore1
OK I am super curious now. What sort of project is using 8 16’ doors? Is wood the best material for this?
