Making a wooden lathe chuck?
Forum topic by dpoisson posted 06-15-2011 06:10 PM 7993 views 2 times favorited 8 replies Add to Favorites Watch
View dpoisson's profile
dpoisson
190 posts in 2876 days
06-15-2011 06:10 PM
Topic tags/keywords: lathe chuck cherry diy
Howdy folks, I was wondering if anyone had ever made a wooden chuck, similar I guess to this:
I was wondering what wall thickness I should use (I’m planning on making this out of Cherry wood). Also, what type of bolts should I use to secure the chuck to my faceplate?
Cheers!
Fish
-- http://picasaweb.google.ca/dpoisson
8 replies so far
View WayneC's profile
WayneC
13751 posts in 4059 days
#1 posted 06-16-2011 02:27 AM
Interesting idea. Not seen this approach before.
View lew's profile
lew
12015 posts in 3717 days
#2 posted 06-16-2011 04:55 AM
I actually made something very similar. The only real difference was that mine was made to be held by my little Nova 4 jaw chuck.
View Cliff De Witt 's profile
Cliff De Witt
130 posts in 2654 days
#3 posted 06-16-2011 03:50 PM
I made one very simular I saw that someone had done one at SWAT last year. It worked okay but limited in range.
I used the Beal Tap to tap threads to match my spindle so I did not have to tie up a faceplate, the $20.00 tap was less expensive than the faceplate. I routinely make glue blocks that thread onto the spindle so I do not have to worry about hitting the chuck as I finish the bottoms of bowls.
-- Trying to find an answer to my son’s question: “…and forming organic cellulose by spinning it on its axis is interesting, why?”
dpoisson
#4 posted 06-16-2011 03:56 PM
Cliff, I’m wondering how solid such a tap would be.
You’re basically just drilling a hole and then tapping it to match your lathe. Then screw your wooden piece and then begin turning?
I’m guessing you used something similar: http://www.leevalley.com/en/wood/page.aspx?p=57074&cat=1,330,49238&ap=1
Fish
View hairy's profile
hairy
2654 posts in 3494 days
#5 posted 06-16-2011 04:00 PM
Here’s a video on making and using one.
http://www.youtube.com/watch?v=rfrldsntWbA
Thanks, Bob!
-- My reality check bounced...
View capnjack2's profile
capnjack2
7 posts in 2499 days
#6 posted 06-16-2011 04:10 PM
Hey! I’m new to this forum but post on WTO from time to time. That chuck looks great to me except that the tenon of the workpiece would have to be about 1/16th shy of the ID of the chuck. That way you allow the piece to get “pinched’ in there when you tighten the hose clamp. I’ll have to try it. I have a few small baseball bats on the to-do list!
Jack
View lew's profile
lew
#7 posted 06-16-2011 05:10 PM
Ditto what Cliff said, too. I make a bunch of blanks, tap them and then glue on the project when needed. I use red oak for the screw on blank.
View MrRon's profile
MrRon
4709 posts in 3205 days
#8 posted 06-16-2011 10:53 PM
Dpoisson; I wouldn’t bother with the dovetailed lip. I’m guessing this is a one off jig and if so, I would make the ID pretty close to the OD of the work piece. I would also line the ID with a medium to coarse sandpaper with contact cement. The wall of the chuck could be pretty much anything, but 1/2 inch sounds about right. Attach the chuck to the face plate with #10 wood screws about 1-1/2” long.
