Front Porch Rockers
Forum topic by bhack posted 194 days ago 99 views 0 times favorited 3 replies Add to Favorites
View bhack's profile
bhack
118 posts in 202 days
194 days ago
Topic tags/keywords: wood finish
Being really new to woodworking, Iwant to build the rocker in the recent issue of WOOD MAGAZINE. I would like suggestions on types of wood to use. The rocker will be on the front porch which is not enclosed so will be exposed to some weather. The article uses oak. What other wood could I use that is durable? We are retired so ththe rocker will get lots of use.
-- Bill - If I knew GRANDKIDS were so much fun I would have had them first.
View trifern's profile
trifern
3987 posts in 249 days
194 days ago
Cypress, Mahogany, White Oak or Teak. The key is to seal it all and keep it sealed. Most stains are not suitable for outside use. If you use a clear coat, use several coats of a spar varnish with UV protection.
-- Depend on the rabbit's foot if you will, but remember it didn't work for the rabbit.
9039 posts in 304 days
194 days ago
Just a note. If you decide to go with oak make sure it is white oak. Red oak will not hold up to the elements the way white oak does.
Varnish will keep it looking good for a time but unless you are prepared to re-do often (at least annually) you may be better off to let it age to a natural silvery gray. The fresh wood look can be maintained but it is a lot of work.
Hope this helps.
View GaryK's profile
GaryK
8482 posts in 470 days
194 days ago
I agree with trifern, except I would skip the white oak. I just don’t care for light colored woods in a chair.
Bookmark And Share This Page
