HF - Heavy Duty Flexible Shaft Grinder/Carver questions
Forum topic by PeteStaehling posted 06-02-2018 12:15 AM 612 views 0 times favorited 7 replies Add to Favorites Watch
View PeteStaehling's profile
PeteStaehling
69 posts in 1353 days
06-02-2018 12:15 AM
I have a Harbor Freight Heavy Duty Flexible Shaft Grinder/Carver on order and am planning to build a router base for it like the one Shipwright built here.
I have a couple questions that I hope someone here can answer.
1. I’d like to work up the dimensions of the base. What is the the diameter of the hand piece?
2. I also want to order some router bits for inlay work. What is the size range of the chuck?
7 replies so far
View Berto's profile
Berto
5 posts in 1724 days
#1 posted 06-02-2018 12:14 PM
Diameter of the hand piece = 63/64” with a micrometer (The thickness of a piece of paper under 1”)
Chuck capacity = 5/32”
-- - Berto in VA - ........"I have nothing to prove and nobody to impress"........
PeteStaehling
#2 posted 06-02-2018 12:19 PM
- Berto
Thanks, that helps a lot.
View shipwright's profile
shipwright
8184 posts in 3032 days
#3 posted 06-02-2018 02:02 PM
Dremel router bits fit fine. Drill a 1” hole for the handpiece and then cut the (wood) piece in half. The kerf removed will allow you to clamp the handpiece tightly.
PeteStaehling
#4 posted 06-02-2018 02:16 PM
Thanks. You never know when Harbor Freight will change stuff, but I took a chance on it fitting and went ahead and made the pieces.
I am anxious to get the HF order, but I’ll have to wait until it arrives. I can’t begin to count all the little jobs where this setup would have been super handy in my luthier work and I am anxious to try using it for inlay work.
I came close to springing for the Fordham tool and the Stewart MacDonald router base, but the price is pretty steep (~$400 vs about $40 and some stuff I already had around with a 25% off super coupon for this setup). This setup will be cheap enough that if I wind up still wanting the Fordham/Stewmac setup, I can chalk it up to experience and not have any regrets. That said I really expect this tool will be plenty adequate and besides I can envision possibly wanting to have more than one set up for different functions, since I often am working in a semi production environment.
View Clarkswoodworking's profile
Clarkswoodworking
288 posts in 367 days
#5 posted 06-02-2018 05:21 PM
I have had one for a few years
Just make sure to lube it good and it will treat you well
Scott
PeteStaehling
#6 posted 06-03-2018 01:23 PM
On a related note…
Anyone have suggestions on a source for 1/8” shaft up cut and down cut spiral router bits between 1/16” and 3/16” or so. Stewart MacDonald has a nice selection of down cut but they are a little pricey. Are there cheaper sources that have decent quality? It seems a bit high to pay $20 for a 1/8” bit. I’d buy a set of various bits to have a variety of functions, but for these bits individual bits may make more sense for my needs.
I was surprised just how poor the selection was at the local Lowes.
PeteStaehling
#7 posted 06-13-2018 11:17 PM
My HF flexible shaft grinder finally arrived. I was happy to find it fit the router base that I made for it just fine.
I ran it a little and it seems like a nice tool. I guess time will tell how well it holds up but for my first testing it works well for the sort of routing I plan to use it for. It seems to have plenty of torque and the variable speed foot control woks well. I am very happy with it so far and can think of a million little jobs it will be hand for. So far I just have the small dremel set of router bits and some other dremel stuff that fits it.
