| Forum topic by Docopac | posted 710 days ago | 1878 views | 0 times favorited | 50 replies | ![]() |
710 days ago |
I have noticed in my shopping for a table saw that some can be used with either 110 or 220 volts. What if any advantage does 220 have over 110 for weekend wood worker? -- Docopac (a carpenter in a different medium) |
50 replies so far
#1 posted 710 days ago |
My vintage saw was terribly underpowered at 110V. A beast at 220V. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#2 posted 710 days ago |
I’m going to put some popcorn on and enjoy the show. These kinds of questions always stir up a lively debate. I’m no electrical expert at all, but what I’ve read indicates the main advantage to 220 is that your saw will likely be the only thing on the circuit, so you will not experience the light dimming and breaker tripping more common when running your saw on a circuit with other household draws on it. In theory, running on 220 will not make your saw more powerful (although Al (Bertha) will disagree). -- Charlie M. "Woodworking - patience = firewood" |
#3 posted 710 days ago |
^I’m pulling up a chair, too, Charlie;) I know that in theory, it shouldn’t. Many electricians (which I am not) have told me this. Maybe my saw defied physics somehow but it struggled on the simplest of task at 110V and blazes without delay at 220V. Nothing else at all was changed on the saw except the wiring. I’m pretty sure I wasn’t in some sort of fugue state and/or dreaming;) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#4 posted 710 days ago |
Al, maybe Rand’s friend, the wood fairy, also does horsepower upgrades on the tools of sleeping Lumberjocks. :-) -- Charlie M. "Woodworking - patience = firewood" |
#5 posted 710 days ago |
Chomp, chomp, chomp,... gulp….burrrp! I’m just watchin’ Al and Charlie go at it…. Chomp, chomp,.... RRRip! Oh ‘sceeuz’ me! Whew!.... I’m outta’ here!... ;-) -- HorizontalMike -- "Woodpeckers understand..." |
#6 posted 710 days ago |
Al, it may seem that way, but the real reason is voltage drop on 110. -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#7 posted 710 days ago |
Topa, -- HorizontalMike -- "Woodpeckers understand..." |
#8 posted 710 days ago |
Oh there definitely are some advantages of 220V over 110V and it does relate to more power at the blade. First off, half the voltage, double the current. Double the current the wiring has to carry quadruple the power loss in the wiring. Hence the voltage drop in the wiring reduces the 110V available at the saw to double that of what it would be at 220V. So roughly as an simple example if you’re pulling 10A at 110V and the wiring has a 1 ohm resistance (it’s not this high this is just for example) you lose 10V in the wiring and the saw sees 100V. That same wiring operating at 220V pulling 5A with the wiring having a 1 ohm resistance has a 5V drop across it so the saw sees 215V. (Assuming typical 20A household circuit wired with 12ga wire for both 110V & 220V.) Losses in this example are 9.1% at 110V, 2.3% at 220V and this scales. This is an exaggerated example and rough calculations (not taking into account it’s actually a divider circuit) to show Voltage does make a difference, the higher the voltage the lower the losses thus more of the power is delivered to the load in this case being the saw. That is why transmission lines are at hundreds of thousands of volts to lower the current thus lowing the losses and delivering more of the power to the load. And power losses in the wiring produces heat and heat increases the resistances which further increases the losses. Physics at its best. Right Topa? And Howdy! -- -Curt, Milwaukee, WI |
#9 posted 710 days ago |
So I wasn’t imagining things, Curt? ;) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#10 posted 710 days ago |
Nope. And I had a buddy that claimed the saw comes up to speed faster too at 220V. Makes sense, haven’t been able to prove that one way or the other though. Makes sense in that voltage is akin to pressure and it’s pushin’ those electrons faster to the load to do the work. -- -Curt, Milwaukee, WI |
#11 posted 710 days ago |
Sweetness. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#12 posted 710 days ago |
Of course if you had a DVR motor there is a major difference, you get just over 1.25-1.5 HP on 110 and a full 2 HP on 220. The reason it seems to come up faster on 220 is most likely due to less voltage drop on the 220 dedicated line. Soon to be a proud owner of a DVR table saw. :-) -- Paul, Beaverton OR, www.TravelbyPaul.com |
#13 posted 710 days ago |
Coming up to speed faster may have something to do with the inrush current as it’s coming up to speed being double hence once again the voltage drop (loss) in the wiring being double thus it takes longer. Theoretically makes sense. -- -Curt, Milwaukee, WI |
#14 posted 710 days ago |
There are benefits to using 220v as mentioned, but the benefits can vary a lot depending on the particular circuit and the particular motor in question. It’s possible that there’s no noticeable difference in some cases, and a very noticeable difference in others. If 220v is readily available, I’d make the switch. If it’s not readily available but lights are dimming and the saw is slow to come up to speed and struggling, I’d consider making the switch. If 220v is not readily available, and there are zero issues with running a tool on 110v, it’s probably not worth bothering. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#15 posted 710 days ago |
Outside of a physics class there is an amazing amount of superstition when it comes to electrical matters. I think a lot of this is from the fact there are so many folks out there that got their electrical knowledge in an apprentice style system. They do something a certain way because their old boss taught them that way. Their old boss did it that way because he learned to do it that way from his boss and so on. Folks will swear up and down certain methods or wiring choices are the only way to go while others will swear up and down that they are wrong. The point is simply this, chances are getting real solid comparison data out of the internet concerning any kind of electrical issue is going to be slim to none. There is however a very obvious and practical difference between the two. All the 220 wiring configurations for motors I have seen use less amps then their 110 counterparts. What this means is that 110 motors of 2hp tend to use at least a full 20 amps and often times are just over that amount. So unless you have a 20 to 30 amp circuit. you can not run a 2hp motor. 3hp motors will need more power still and since most folks are not running 30 amp outlets they might as well re-wire for 220 volt. This issue becomes even more prevalent when you run out of amps in your box and still need to power your machines. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
