Large Walnut Rounds - Need Project Idea...
Forum topic by Buke posted 05-29-2018 09:18 PM 1577 views 0 times favorited 13 replies Add to Favorites Watch
View Buke's profile
Buke
4 posts in 25 days
05-29-2018 09:18 PM
Topic tags/keywords: rounds
I’ve lurked around this forum from time to time over the last 4 or 5 years but until now haven’t been in a place to do any wood working so I never bothered to make an account. So, forgive me if this is in the wrong forum.
My parents cut down a big old black walnut tree in their yard a few years back. I don’t remember what happened to the bulk of the wood but my dad kept 5 big rounds from the base of the tree. They’ve been air drying in the barn ever since and remarkably they don’t seem to have checked too bad.
Now I’m looking for ideas on how to use them. They have some character but I have to admit, the wild curves and what not don’t really fit the 1958 mid century aesthetics of my house.
Any ideas about how best to use them? Does anyone have any examples where they’ve used similar pieces?
13 replies so far
View bobasaurus's profile
bobasaurus
3487 posts in 3212 days
#1 posted 05-29-2018 09:28 PM
You could build a router slab flattening jig to get them pretty flat, then fill the cracks with epoxy and sand flush. They would make nice end tables or wall decorations.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View Aj2's profile
Aj2
1442 posts in 1826 days
#2 posted 05-29-2018 10:12 PM
How about a very large end grain cutting board for Fred Flintstone. :)
-- Aj
View Buke's profile
Buke
4 posts in 25 days
#3 posted 05-30-2018 08:59 PM
I hadn’t thought about a giant’s cutting board :)
The end table is the obvious choice, but it just doesn’t go with my houses aesthetic. Maybe I’ll plane one flat and clean it up and see if I get inspired.
View Lazyman's profile
Lazyman
2057 posts in 1415 days
#4 posted 05-30-2018 09:08 PM
You could do a rustic/mid-century fusion table by using hairpin legs?
https://www.1stdibs.com/furniture/tables/coffee-tables-cocktail-tables/mid-century-slab-coffee-table/id-f_583056/
View JCamp's profile
JCamp
640 posts in 578 days
#5 posted 05-30-2018 10:33 PM
End tables or nights stand. Something a bit different would b a checker or chess board.
Honestly a thin one would make a really awesome clock to hang on the wall.
Also… welcome to LJs
-- Whatsoever thy hand findeth to do, do it with all thy might
View Buke's profile
Buke
4 posts in 25 days
#6 posted 05-30-2018 11:21 PM
I wonder what would happen if I squared off the edges so that I was left with 5 big end grain blocks, then I laid them all out in a line and then wrapped a wide oak or ash board around the perimeter to create some contrast to the walnut end grain sections. That would create a big dining table with a unique character. It seems like there would be a bunch of potential for differential shrinkage and movement because of the table top being made of lumber in different orientation, but maybe not.
View HerbC's profile
HerbC
1764 posts in 2887 days
#7 posted 06-01-2018 12:44 PM
Buke, you have just described the steps to create a legendary “Panel of Doom” which will self destruct due to failure to account for and compensate for wood movement differences between the different elements of the structure…
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Lazyman
#8 posted 06-01-2018 02:31 PM
Perhaps if you leave the edge strips off it could be made to work. Instead of edge strips perhaps a profile such as beads. The only situation where I have seen someone join wood oriented like that is in an end grain cutting board which usually involves narrow strips or small blocks. Perhaps if you cut the rounds in such a way that you wind up with grain in a similar orientation along the matching joint edges?
I’ve never done it so I am just throwing out ideas so others can shoot them down.
View RobHannon's profile
RobHannon
110 posts in 558 days
#9 posted 06-01-2018 02:47 PM
Make 5 end/coffee tables and sell them. Then buy more tools.
View Aj2's profile
Aj2
#10 posted 06-01-2018 04:56 PM
Why don’t you try it a see what happens. Perhaps there’s something to learn.
Be sure to glue the oak border real good and tight.:)
-- Aj
JCamp
#11 posted 06-01-2018 06:34 PM
Do what Rob said. U could probably get a couple hundred a piece for the end tables
View Buke's profile
Buke
4 posts in 25 days
#12 posted 06-01-2018 07:03 PM
Alright, I think the consensus is in line with my initial thoughts. gluing up multiples of these things is a bad idea.
Did I mention I’m pretty new to woodworking. I took a couple years of wood shop in high school, helped my grandpa with a few projects and then basically did nothing for 20 years.
I like the clock idea. I’m not sure that I can convince my wife that it would fit our aesthetic. Same with the end table.
Thanks for all the input.
View JayT's profile
JayT
5679 posts in 2239 days
#13 posted 06-01-2018 07:08 PM
Find another woodworker and do a wood swap. Trade the walnut for plank lumber that you can use to build things you want. It’d be a shame to cut those into smaller pieces, when there are good uses for them that they naturally lend themselves to without alteration.
Don’t know where you are located, but I’d bet there are more than a few LJ’s on the site would be happy to do some kind of trade. I know I would.
