Table saw question
Forum topic by Scotty30815 posted 05-28-2018 04:58 AM 842 views 0 times favorited 12 replies Add to Favorites Watch
View Scotty30815's profile
Scotty30815
1 post in 121 days
05-28-2018 04:58 AM
Does anyone know what’s wrong and how to fix it?
12 replies so far
View knotscott's profile
knotscott
8122 posts in 3497 days
#1 posted 05-28-2018 10:59 AM
Can you give us a brand and model #, and some more pics?
View Redoak49's profile
Redoak49
3455 posts in 2110 days
#2 posted 05-28-2018 11:10 AM
The more info you supply the more help you will get.
What are the symptoms?
View bondogaposis's profile
bondogaposis
4931 posts in 2473 days
#3 posted 05-28-2018 01:13 PM
What are we looking at?
-- Bondo Gaposis
View WhyMe's profile
WhyMe
1049 posts in 1683 days
#4 posted 05-28-2018 01:59 PM
Looks to me that a c-clip or screw fell off allowing things to come apart. If nothing is actually busted it may be a matter of just putting it back together.
View Jim's profile
Jim
16 posts in 211 days
#5 posted 05-28-2018 04:21 PM
I’d suggest going to the web site ereplacement.com than load your model and type in to the locater. This site has excellent breakdown diagrams. With a little studying I’m sure you’ll have a better idea of whats wrong. For what ever reason, the adjustment screw has come loose and allowed the guide to fall out of it’s groove
-- Imitating is the best form of flattery
View Woodknack's profile
Woodknack
12341 posts in 2502 days
#6 posted 05-28-2018 07:10 PM
The doohickey popped loose from the thingamajig. I think something bent or you lost a retaining clip.
View Ripper70's profile
Ripper70
1115 posts in 1030 days
#7 posted 05-28-2018 07:12 PM
Does anyone know what s wrong and how to fix it?
- Scotty30815
Is this a trick question?
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View BurlyBob's profile
BurlyBob
5899 posts in 2387 days
#8 posted 05-28-2018 08:59 PM
I’m with Bondo, what the heck is that?
View GrantA's profile
GrantA
401 posts in 1529 days
#9 posted 05-28-2018 09:08 PM
Took me a second, I’m guessing it’s a portable table saw and that’s a picture from underneath the blade height adjustment assembly, after a clip has left it’s post
View Kazooman's profile
Kazooman
1117 posts in 2074 days
#10 posted 05-28-2018 10:02 PM
Don’t listen to those other guys. Clearly you have run out of Dilithium Crystals. Hence, your warp drive is warped.
I think you used to be able to purchase Dilithium Crystals at Woodcraft, but they might be back ordered. Good luck.
View mrg's profile
mrg
828 posts in 3121 days
#11 posted 05-28-2018 11:14 PM
After opening the photo and looking at the image it looks like the threaded piece needs to be put back in the hole in the bracket. It looks to be held in with a c-clip. The piece that the threaded bolt goes through with the two nuts rides in the grooves in the bracket.
As said above look up the parts schematic on replacements and you should see how it goes together or what parts may be missing.
Tell us the make and model and we may be able to help further.
-- mrg
Ripper70
#12 posted 05-29-2018 12:52 AM
Here’s your problem. Fix that and you’re good to go!
