Crosshatching jig? Ideas?
Forum topic by totalrewind posted 05-27-2018 11:17 PM 691 views 0 times favorited 11 replies Add to Favorites Watch
View totalrewind's profile
totalrewind
44 posts in 2514 days
05-27-2018 11:17 PM
Topic tags/keywords: jig router
Hey all,
I have a problem. My drill press vice jaws have a series of diagonal cross-hatches, which are worn out.
I tried cutting them back in with a hacksaw blade, but I have a hard time keeping it from wandering and ruining the groove. Plus it’s tedious and my thumbs are getting pretty sore.
What I really want to do is unscrew the jaw face, toss a v-groove bit in my router and zip it out, but that leads to the question in the title: How to make a series of straight lines at a set spacing from one another?
There has to be a simple solution, but I’m at a loss what that might be.
Thoughts?
-Kurt
-- For more projects (not just woodworking) check out my project blog at http://theheadlesssourceman.wordpress.com
11 replies so far
View John Smith's profile
John Smith
1555 posts in 404 days
#1 posted 05-27-2018 11:27 PM
if you can get the jaw faces off, you could run the cutting wheel
on an angle grinder in the existing groove with more accuracy than the router.
the vice that I have, the jaw face is held on with two hex screws on each jaw.
..... (that’s what I would do).
-- I started out with nothing in life ~ and still have most of it left.
View GrantA's profile
GrantA
970 posts in 1649 days
#2 posted 05-28-2018 12:47 AM
Wow I had to go back and read that again, I thought you were talking about cross hatch on the chuck, imagining that you were somehow gonna cut that with a router!
I’d suggest a triangular file
John Smith
#3 posted 05-28-2018 01:20 AM
if you don’t have the angle grinder and you really don’t have a problem with the router,
you could cut out a cavity in a board that the jaw would fit flush in, then you could free-hand
the V bit through the existing grooves. that way the workpiece would be flush with the router base.
put a couple of screws in the jaw to make sure it doesn’t move
wa-la = done deal
View hairy's profile
hairy
2783 posts in 3774 days
#4 posted 05-28-2018 12:20 PM
https://www.youtube.com/watch?v=uT8JIdOf-6w
Maybe this will help. It’s a wooden meat mallet with a crosshatched head.
-- My reality check bounced...
John Smith
#5 posted 05-28-2018 01:01 PM
Kurt – I was “assuming” the jaw faces were metal ~ are they wood ???
View splintergroup's profile
splintergroup
2517 posts in 1464 days
#6 posted 05-28-2018 01:57 PM
I hope they are wood!
View GR8HUNTER's profile
GR8HUNTER
5404 posts in 954 days
#7 posted 05-28-2018 02:47 PM
they better be WOOD :<)))) LOL
totalrewind
#8 posted 05-28-2018 03:32 PM
The jaws are cast iron. Fairly soft for metal. I’ve seen guys cut that with carbide router bits (https://www.youtube.com/watch?v=Urz57RVC15A), but of course, the harder the material, the shorter the lifespan, I’m sure.
Thanks John Smith. I do have an angle grinder just hanging there on the wall right in front of my face, yet for some reason that never occurred to me. I see how the cutting wheel would help to keep the line straighter. (Just don’t wanna sneeze and cut the thing in half! LOL!)
That doesn’t help with the spacing, but combined with hairy’s video, I’m starting to get a nugget of a plan in mind. I’d need to figure out how to mount a grinder in place of the router—an interesting sounding tool to have around, now that I think about it.
Or, as suggested, just freehand the dumb thing and call it good enough.
Thanks everyone for your input!
John Smith
#9 posted 05-28-2018 03:56 PM
like I tell a lot of my cohorts – it’s a WORKING TOOL – not a piece that
will go on your great-grandmothers antique china cabinet !!
share some pics when you gitter dun.
and as for a wood router bit in iron – on my last table saw, I had a nasty “scar”
in the cast iron table where I didn’t lock the router depth handle and a 3/4”
pattern bit slid down about a 1/8” by 6” long before I noticed the mishap.
(a little Bondo and all is good).
so, I know from experience that a carbide router bit designed for wood will
definitely cut cast iron and other soft metals.
View oldnovice's profile
oldnovice
7380 posts in 3609 days
#10 posted 05-28-2018 04:08 PM
How about a wide cold chisel and hammer; file or sand down the burrs?
View wichman3's profile
wichman3
83 posts in 863 days
#11 posted 05-28-2018 04:29 PM
Do you have an oscillating multi-tool? A diamond half round cutter would handle the cast iron, and this tool would be much easier to control.
Or
A metal cutting blade in a tablesaw, used with a fingerjoint jig.
