Advice on castiron repair
Forum topic by zindel posted 06-10-2011 04:09 PM 2346 views 0 times favorited 31 replies Add to Favorites Watch
View zindel's profile
zindel
257 posts in 2617 days
06-10-2011 04:09 PM
So a few weeks ago i scored on an old Powermatic jointer the only issue there is a small part that is broken, it has no affect on the operation or accuracy it just makes the table wobble while adjusting the infeed but i have the part that is broken off and i would like to be able to at least JB weld it back on? Anyone have any advice if this will work on not? i have heard that if you just grid the cast iron down enough to allow some place for the jb to sit it will hold quite nicely. it is just like 1 inch of the track that the infeed table sits on. Still works fine without it.
-- If you can't fix it with a hammer, You've got an electrical problem.
31 replies so far
View crank49's profile
crank49
4030 posts in 2938 days
#1 posted 06-10-2011 04:50 PM
JB, in my opinion will work for cosmetic repair. I would not expect it to have much structural strength; depends on how much surface you have in the bond. You need some mechanical support for the bonded materials. Think of the difference in a butt joint and a dovetail joint when it comes to strength. Glued metal is not that much diffrent than glued wood in that regard.
A true repair requires brazing or welding with nickel rod. Brazing and welding both may require pre-heating. Cast iron is just not easy to fix.
View helluvawreck's profile
helluvawreck
30765 posts in 2834 days
#2 posted 06-10-2011 05:12 PM
Sometimes we have a wreck on one of our molders and break a cast iron part. We usually have it brazed. It will usually last quite a while and may never break again. In my experience, brazing takes someone that knows what they are doing.
View Planeman40's profile (online now)
Planeman40
1155 posts in 2728 days
#3 posted 06-10-2011 05:26 PM
Ditto on the brazing.
Cast iron brazes well using brass filler rod and a brazing flux made for cast iron, This is done with an oxy-acetylene torch. The repair should be permanent
Planeman.
zindel
#4 posted 06-10-2011 05:42 PM
Well like i said its not a big issue its more of a cosmetic thing and sadly i did not buy it this way it was during transport that this happened. once the table is set it does not matter…just wanted to see if anyone tried any type of glue for more of a look than support.
zindel
#5 posted 06-10-2011 05:43 PM
But i wish i knew how to braze or someone who did because that would be handy!
View Bertha's profile
Bertha
13521 posts in 2660 days
#6 posted 06-10-2011 07:15 PM
I wonder if you couldn’t just pin it somehow, then bondo & paint. I know that’s not exactly the “right” way to do it but if a simple bolt will keep it from rocking, and the rest is only cosmetic, who knows. I’m just thinking aloud here. When I worked in the brewing industry, we had a guy who was a really good braizer and about 20 guys who thought they were. We had quite a few big cast iron breaks relating to grain hoppers.
View dbray45's profile
dbray45
3320 posts in 2744 days
#7 posted 06-10-2011 08:15 PM
I have brazed and welded steel and iron but I would not touch cast iron. Cast iron has this tendency to break, crack, explode while heating – but then again, I am not a professional welder.
This would take a good welder/fabricator to fix this correctly.
-- David in Damascus, MD
View MedicKen's profile
MedicKen
1612 posts in 3429 days
#8 posted 06-10-2011 08:33 PM
JB Weld should be fine for the repair. If you want to weld it I would suggest taking it to someone with experience in welding cast. I can be brazed as well. If welded the parts should be preheated and then welded with a high nickle rod and then allowed to cool SLOWLY.
View BobTheFish's profile
BobTheFish
361 posts in 2519 days
#9 posted 06-10-2011 11:37 PM
I’d go with what everyone else says, but in my experience, cast iron is not an easy fix, and even if fixed, it’s still not the greatest of repairs. Cast iron is the least iron-pure, carbon heavy variety of iron/steel made if memory serves correctly, and it’s just really brittle and easy to damage. I definitely wouldn’t attempt to repair yourself.
View Don Johnson's profile
Don Johnson
685 posts in 2748 days
#10 posted 06-11-2011 03:46 PM
Sorry to go off topic, but elsewhere someone mentioned that he always misreads a poster’s name as something quite different – when I saw this topic, I thought it was ‘Advice on Castration Repair’
My brain is going ! LOL
-- Don, Somerset UK, http://www.donjohnson24.co.uk
13600 posts in 3308 days
#11 posted 06-12-2011 04:23 AM
off topic too
don
for ‘Advice on Castration Repair’
your answer is in cr1’s response
“Ya gotta heat the whole thing to 900 Degrees”
good luck with that lol
View skeeter's profile
skeeter
233 posts in 3308 days
#12 posted 06-12-2011 04:34 AM
nickel rod and a grinder
-- My philosophy: Somewhere between Norm and Roy
View papadan's profile
papadan
3584 posts in 3335 days
#13 posted 06-12-2011 04:46 AM
I use Nickle and DC welder for cast iron quite often, Zindel, where are you located? Maybe an LJ could give you a hand with it.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3074 days
#14 posted 06-12-2011 05:49 AM
Zindel, where you located? If you are near Southern California, I can fix it for you. Since the piece is already broken off, the pre heat is not necessary. Preheat is just to keep the crack from traveling. I still have a ton of a stainless rod I have used for years and never had a failure with it. It will leave a slight discoloration in the metal in the repaired area.
I looked for the numbers on the rods but they seem to have disappeared.
If you know a welder or have the capabilities yourself I would be glad to send you a handful to make this repair. The important thing is to grind a V notch for the rod to fill in, then sand the bead smooth. It is a 3/32 rod that requires about 75 amps DC. I will be glad to walk you through it on the phone as this rod takes all the high tech out of welding cast iron. We used to call it Super Missile Rod. lol I paid $35.00 a lb back in the 80’s. Worth every penny too.
I believe the manufactures name is Nemco and the rods tensile is in the neighborhood of 130,000. I have used this stuff on every thing from engine blocks to huge electric motor frames, to valves in oil refineries etc. Much easier to use than Ni-rod and much stronger.
Brass rod with plain old Borax works great too, unless you have a high stress in the area. If I can help, PM me.
zindel
#15 posted 06-12-2011 06:12 AM
Wow thanks guys! I live in Nebraska but thanks for the great offer lilread! I think i will give JB a try since it doesn’t hold much pressure anyways. If you know any jocks in Nebraska i would always like to meet them though!
showing 1 through 15 of 31 replies
