Panel glue up tips?
« back to Joinery forum
Forum topic by leftcoaster posted 05-25-2018 02:42 PM 637 views 0 times favorited 9 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
233 posts in 1113 days
05-25-2018 02:42 PM
When edge joining panels I rely on clamps and cauls to get a flat panel with good adhesion.
Anyone have tips for minimizing or managing squeeze out under the cauls and clamps? Especially but not exclusively on the bottom side?
9 replies so far
View John Smith's profile
John Smith
1544 posts in 399 days
#1 posted 05-25-2018 02:50 PM
use less glue
put a piece of plastic or masking tape on the clamp at the glue joint (top and bottom)
to minimize the darkening of the wood
put news paper under the panel to keep the glue off your work table.
use less glue
in my world, the dried glue on the underside is easier to clean up than the top.
[Use Less Glue to minimize the excess]
-- I started out with nothing in life ~ and still have most of it left.
View lew's profile
lew
12498 posts in 3992 days
#2 posted 05-25-2018 03:38 PM
wax paper works well. Store brand is cheaper.
View splintergroup's profile
splintergroup
2502 posts in 1459 days
#3 posted 05-25-2018 06:44 PM
I like to place the panels together (without glue), then apply some paste wax over the joint.
Use the tricks John and Lew mention to keep your clamps and work area clean and do the glue up.
After maybe 30 minutes, you can remove most of the squeeze out with an old credit card or whatever and not need to work as much about smearing it into the wood.
The wax keeps the glue out of the wood pores and after the joint is dry, you can remove any wax remains with a rag and mineral spirits
View OSU55's profile
OSU55
2026 posts in 2226 days
#4 posted 05-25-2018 07:08 PM
Ive tried some various things, and the following works best for me:
- Cauls are waxed all over, faces have packing tape applied & then waxed
- Clamp bars are generously waxed
- Something under the panel (I use the brown paper painters drape on a roll) to keep it off the bench
- develop a specific dried glue removal process, i.e. I use an old chisel to get the worst of it, then a #80 cabinet scraper to get up to ~95%, then the flattening planes get the rest.
- Dried glue is very easy to remove from waxed surfaces
I tried removing the glue before it sets up – hard to get the timing right. Limiting the amount of glue would cause joint areas without enough.
View pintodeluxe's profile
pintodeluxe
5816 posts in 3050 days
#5 posted 05-25-2018 08:42 PM
I use duct tape on my cauls, but otherwise let-R-drip. Let the glue partially harden, and it’ll scrape right off.
A short length of blue painters tape on the clamp bar helps keep the clamp clean.
I gave up on wax paper years ago because it can keep the glue from drying.
View recon49's profile
recon49
16 posts in 241 days
#6 posted 05-28-2018 03:03 AM
I’ve seen how good the wax paper works.
View AlaskaGuy's profile
AlaskaGuy
4989 posts in 2546 days
#7 posted 05-28-2018 03:37 AM
What they said + learn to apply the right amount of glue. Take some scrap the same thickness as the stock you will be gluing up and practice buy applying different sized beads until you find the right size. It won’t take many to tries to figure this out. You don’t have to actually glue up the test pieces. Just glue them, clamp them and see how much squeeze out you get then pull them back apart.
View Rich's profile (online now)
Rich
4000 posts in 826 days
#8 posted 05-28-2018 03:44 AM
To keep glue from sticking to clamps, I use Bates glue release. Just wipe the clamp bars down and glue will pop off. There’s no need to apply it every time, so a $20 quart will last years.
On my cauls, I used to use packing tape, but have switched to vinyl stucco tape. Its red color means I’ll never again put a caul on upside down and have it glued to my panel :)
To protect my bench, I either use 24” wide craft paper that I buy in 2500’ rolls, or grilling mats that glue does not stick to. Amazon sells a 70 by 16 inch roll of the grilling mat material for $13.
View TravisH's profile
TravisH
641 posts in 2172 days
#9 posted 05-28-2018 04:05 AM
I bought about 6 feet of vinyl runner from the carpet section at the big box store. Catches any drips and when I roll it up they flake off. The stuff I bought was less than a 1.50 a ft. Been using it for about 6 years now without any issues. I do wish it was wider but easy enough to overlap if needed.
