Fractal burning solution?
Forum topic by becikeja posted 05-25-2018 11:51 AM 2518 views 0 times favorited 13 replies Add to Favorites Watch
View becikeja's profile
becikeja
962 posts in 3047 days
05-25-2018 11:51 AM
A couple of weekends ago I came across an old neon sign for $25 (the tubes were broken) so I bought it for the transformer. This weekend I plan to transform it into a fractal wood burning machine and give a try.
It seems that most use a baking soda mixture of one cup of water and a tablespoon of baking soda. Just wondering what other solutions have been tried, results, etc…....
Any opinions / suggestions?
13 replies so far
View gwilki's profile
gwilki
238 posts in 1708 days
#1 posted 05-25-2018 01:14 PM
I’ve used salt in water, with about the same results as baking soda. I found that, on some woods, baking soda really darkens the colour.
Be very, very careful out there. As I’m sure you already know, this practice can kill you.
-- Grant Wilkinson, Ottawa ON
View Kilo19's profile
Kilo19
99 posts in 460 days
#2 posted 05-25-2018 02:46 PM
I ve used salt in water, with about the same results as baking soda. I found that, on some woods, baking soda really darkens the colour.
Be very, very careful out there. As I m sure you already know, this practice can kill you.
- gwilki
Yea, I remember a video where they guy was like 110v it’ll give you a chance, bite, oh that hurts…this, if you mess up there is no second chance, and as a noodler once said “you’ll be having supper with jesus tonight”.
If I ever made one, I’d make some kind of dead man switch, double redundant etc….
-- Justin
View splintergroup's profile
splintergroup
2499 posts in 1456 days
#3 posted 05-25-2018 06:52 PM
I use a soda solution and a small spray bottle (lens cleaner bottle) to mist the wood surface. Most any other ionizer such as salt will also work.
Wood selection is important as the solution tends to absorb more in the grain rings, causing the burning to follow. Non-grainy woods such as maple and birch ply give better “lightning” patterns as the burning follows a more random pattern.
Typically I’ll attach the electrodes to the ends of the board, then spritz the surface with the solution. I then energize the setup and use further spritzes to control the patterns as they develop.
View Rick S...'s profile
Rick S...
10923 posts in 3267 days
#4 posted 05-25-2018 08:25 PM
- gwilki
Very, Very Careful! Yes. It can KILL You!
-- Made In Ontario, CANADA
View Kelly's profile
Kelly
2179 posts in 3178 days
#5 posted 05-25-2018 09:03 PM
I like the idea of a solid fiberglass painter pole, and a 1” rubber mat (I use horse mats for the floor of my shop) under me, if I were doing this, and I made my living around electrons and the occasional high voltage device (e.g., RF transmitters).
View Steve Peterson's profile
Steve Peterson
395 posts in 3316 days
#6 posted 05-25-2018 09:05 PM
Do a lot of research on safety before starting. Also search for Lichtenberg wood burning. Some of the designs are really beautiful.
Please post some pictures if you survive the weekend. :)
-- Steve
becikeja
#7 posted 05-26-2018 03:08 AM
No worries, and I really do appreciate the concern. I’m 30 years in the electrical distribution industry, well aware of the risks and safety precautions to take. I plan to use a double palm switch requiring both hands to hold the circuit closed. If either hand breaks connection the circuit will open.
woodbutcherbynight
5824 posts in 2643 days
#8 posted 05-26-2018 04:23 AM
- becikeja
In adding to your safety protocols have someone with you. Explain what is going on, and what can go wrong, and what to do if it goes wrong. In Iraq we called this a TSTI (total safety task initiative) While a pain to take time to do it did prevent accidents when used, and if an accident occurred everyone involved knew what to do.
becikeja
#9 posted 06-04-2018 01:02 AM
Burned a lot slower than I had anticipated, but worked well.
I ran a test on Pine, Oak Plywood, and Mahogany. The Pine created a nice burn but the wood turned green from the baking soda solution, same effect on the oak. Was not expecting the green tint. The Oak Plywood was disappointing. The Mahogany darkened front the solution, and gave a really nice result. The Mahogany was definitely the best result.
Any idea why the Pine and Oak turned green?
Kelly
#10 posted 06-04-2018 01:48 AM
Tannic acid fighting with baking soda?
View jerryminer's profile
jerryminer
944 posts in 1676 days
#11 posted 06-04-2018 02:20 AM
Pics?? (No pics= didn’t happen :-) )
becikeja
#12 posted 06-04-2018 06:26 PM
splintergroup
#13 posted 06-04-2018 06:34 PM
See if the “green” sands away. I thing the figures always look better after a sanding with a R.O. and 220 paper. The fine details really come out.
