50 Cent Fix
Forum topic by tenontim posted 199 days ago 208 views 0 times favorited 10 replies Add to Favorites
View tenontim's profile (online now)
tenontim
915 posts in 229 days
199 days ago
Topic tags/keywords: table saw splitter kick back blade binding tip
I have seen several post from people asking about saw blades binding and splitters, etc. I’ve also looked at a lot of the work shops that everyone has posted on their page. The majority of table saws that I see don’t have any kind of blade guard on them. I’m guilty myself. I also have one thumb that’s a little thinner than the other. But it wasn’t enough to make me put a guard on my saw. I just try to be more careful, pray I don’t repeat my blunder, and use the saw without a guard rather than be inconvenienced by it getting in the way.
I wanted to post a cheap fix that I did to my saw that will at least keep your blade from binding, burning the edges of your cut, and prevent some of the kick back you may be getting. It’s a splitter made from a piece of strap steel, 1”W X 3 1/4”L X 1/8” T. Drill a hole to match up the mounting hole where your guard usually mounts, making sure the bottom edge sits against the lip on the bottom of the mounting. I angled the top of mine to make it a little more streamlined. Most saws have an adjustment so you can line up the splitter with your blade by tilting the splitter one way or the other.
-- Tim -- http://tmuli.com
View Woodshopfreak's profile
Woodshopfreak
329 posts in 227 days
199 days ago
cool. Very inovative. Great problem solution.
-- Tyler, Illinois
tenontim
199 days ago
Tyler, you’re one of the few that still had the guard on your saw. It’s got the splitter built in.
teenagewoodworker
2031 posts in 253 days
199 days ago
cool. i don’t even think my saw has anywhere where i could attach a splitter. when i get a nice one though i’ll make sure i can mount one though. thanks for the post!
View Tony Z's profile
Tony Z
134 posts in 274 days
199 days ago
I did something similiar to this with my saw. I have the Craftsman Professional Hybrid saw and it has a slot behind the blade with a spring clip to hold the guard and splitter on. I don’t use a guard either but I took a piece of 1/8” plywood and cut it to fit tight in the slot. I also sanded a wedge profile on the front edge of it so it would slide easily throughthe kerf. It works great and is easily removed thanks to that spring clip slot.
-- Tony, Ohio
View jcees's profile
jcees
465 posts in 283 days
199 days ago
I use a splitter for ripping ops. It’s a waste and usually in the way on crosscuts and darned near everything else. ALL blade guards are nothing more than idiot proofing devices that block your view of the blade and the work being fed to it. Not good. I prefer seeing what I’m doing and what’s going on with my cuts. I’m funny like that. The BEST safety device is located between your ears rather than some Rube Goldberg device suspended or attached to your tablesaw. And I don’t even care if it sucks dust too. That’s why God created bench brushes, brooms, dust pans and ShopVacs.
Rather, I’ve got a couple of throat plates that I’ve installed an aftermarket splitter on. I’ve found that it’s a lot easier to swap those instead of having to get out a wrench to remove the other style splitter attached beneath the table. Just my two centavos.
always,
J.C.
aka The other white meat
-- "Imagination is more important than knowledge" -- Albert Einstein
tenontim
199 days ago
Those throat plates work good too, Meat. I do have to remove this for dado cuts, but it is nice to have when I’m making an angle cut. And officially, my guard has been removed for clarity :0)
View GaryK's profile
GaryK
8483 posts in 473 days
199 days ago
Interesting solution.
9077 posts in 306 days
198 days ago
This is an interesting post. I am sure you decided to post it after looking at my shop. :) I do need to add both the splitter and guard. Like you I have a left index finger that I tried to sharpen on the saw but, while I respect the tool, it doesn’t deter me from running it w/o the safety devices. I have been considering putting a splitter on. I may have to borrow your idea.
Thanks for the psot.
View Sawdust2's profile
Sawdust2
848 posts in 572 days
198 days ago
This costs a little more that $.50
Micro Jig, Inc. has various splitters for thin and thick kerf blades.
www.microjig.com
If you want a splitter and don’t have a way to fasten one to your saw this will fit the bill.
View rikkor's profile
rikkor
7632 posts in 359 days
198 days ago
That is a good idea.
-- Maplewood, MN
Bookmark And Share This Page
