Tips to finish a wood table
Forum topic by Nadia posted 05-24-2018 06:49 PM 371 views 0 times favorited 4 replies Add to Favorites Watch
View Nadia 's profile
Nadia
7 posts in 237 days
05-24-2018 06:49 PM
Topic tags/keywords: wood table finish high pressure laminate tips
Hello,
I have a wooden table that I made myself; it has never been painted and comes from a tree stump. I let it dry for two years and is now ready to be polished. I would like to know what are your tips and consiels.
I would like it to look a bit like one of those high pressure laminate finishes. I think it’s possible; just put some color and luster, but I do not want to do anything. Some have already done the project?
Here is the table : https://s3.amazonaws.com/vs-lumberjocks.com/p98w5t5.jpg!
Thanks!
-- Nadia, Montreal, www.mobilia.ca
View John Smith's profile (online now)
John Smith
1539 posts in 397 days
#1 posted 05-24-2018 07:06 PM
I am guessing this will be an INSIDE table ??
by ~ is now ready to be polished – do you mean sanded down smooth and a clear finish applied ??
-- I started out with nothing in life ~ and still have most of it left.
View OSU55's profile (online now)
OSU55
2022 posts in 2224 days
#2 posted 05-24-2018 08:06 PM
Since you dont want to do anything, what exactly is your question?
Nadia
7 posts in 237 days
#3 posted 05-24-2018 08:14 PM
Yes, it is an inside table. I want to do something, but not anything:) I want to make sure that I will not mess it!
OSU55
#4 posted 05-24-2018 08:28 PM
If you want to fill the cracks investigate epoxy, and there are various fillers or color that can be used to decorate the cracks. I assume you want a wipe on or brush and not a sprayed finish. For wiping or brushing, oil based poly. How much will it be used? A thin wipe on film finish will work well for light use, but a thicker, brushed film is needed for heavy use. I use wd lockwood oil based dyes mixed into poly to add color – works very well. Can add to this if interested.
