Router
Forum topic by Jean-Marc posted 06-09-2011 02:15 PM 1695 views 0 times favorited 8 replies Add to Favorites Watch
View Jean-Marc's profile
Jean-Marc
7 posts in 2448 days
06-09-2011 02:15 PM
Hi, I live in Belgium and I am looking after fixed base router for free-hand routing, unfortunately in Europe the fixed base router does not exist. Can I modified a plunge router into a fixe base router.
I am llookind after a model where the handles is near the base, in order to be able to route with the forearms on the table.
-- Jean-Marc
8 replies so far
View richgreer's profile
richgreer
4541 posts in 2979 days
#1 posted 06-09-2011 06:03 PM
If you take a plunge router and lock the plunging mechanism is place you, effectively, have a fixed base router. You could probably make the lock up permanent with epoxy glue or drilling a hole and inserting a bolt, if necessary.
The only difference is weight and balance. Plunge routers tend to be more top heavy and a little heavier in general.
View Bertha's profile
Bertha
13504 posts in 2598 days
#2 posted 06-09-2011 06:31 PM
You can just lock down a plunger but like Rich says, they’re big and bulky. The Porter Cable 690 is well respected, reasonably priced, and I would think available almost anywhere. Perhaps you have access to a used plunger?
Jean-Marc
#3 posted 06-09-2011 07:17 PM
I was willing to order a Porter Cable but unfortunately it runs on 110 volts , here in Belgium wehave 220 V
-- Jean-Marc
View Greedo's profile
Greedo
473 posts in 2865 days
#4 posted 06-09-2011 08:28 PM
Hello Jean Marc, i also live in Belgium and Bosch has a fixed base router available here.
the GMF 1400 :
i have it under my router table, it is very well built and powerful though it’s quite expensive (official price €540)
Jean-Marc
#5 posted 06-09-2011 08:50 PM
Hi Greedo,
Yes you are right, I took notice of this Bosch GMF 1400, but since I will need 3 in quantity ( it’s quite expensive),I need 3, in order not to change the bits everytime, while doing signs. Also about the power 1400 Watt, about 1 3/4 HP. Doing signs is mainly a freehand routing, some experts in signmaking suggest me a 3/4 or 1 HP, (600 to 900 Watt), since it’s a 100% hand held.
The same router in the US cost 179 $ at Porter Cable and here it’s + – 540 euros CRAZY those Belgium supplier.
-- Jean-Marc
Greedo
#6 posted 06-09-2011 10:10 PM
Bosch used to make 500W (green) routers with low handles, occasionally there are some that pop up for sale and they are quite cheap:
POF 52
i don’t know of anything new that could suit your use, maybe regular plunge routers and add hadles yourself on the base.
View Dan Lyke's profile
Dan Lyke
1519 posts in 4029 days
#7 posted 06-13-2011 10:59 PM
Most routers have a detachable base plate. You could build your base and handles on a base plate that screws on to the bottom of almost any router. Since you aren’t going to be taking off much stock while working freehand, the reduced routing depth that a ½” or so thick baseplate should be no problem. See, for instance, Pat Warner's offset baseplate.
When I did my curved shelf, the laminated front edge wasn’t aligned terribly well and I built an offset raised baseplate to let me use my router to bring it down to the same level as the plywood shelf. Worked fine.
Jean-Marc
#8 posted 06-14-2011 08:33 AM
I came across this router, never heard before, the Draper router Expert 1350Watt 230V
I caan buy it from the UK, it look like a fixe porter cable router. Did someone know this machine, it’s a real alternative for competitive fixed base router in Belgium and France.
http://www.tooltrolley.co.uk/promotions-4101/draper-air-power-4106/draper-mr1350k-45368-draper-expert-1350w-230v-combination-router-kit-28684.html
-- Jean-Marc
