Using Veritas cabinet scraper to clean up desktop panel post-glue-up?
Forum topic by HTX_woodworker posted 05-24-2018 01:04 AM 479 views 0 times favorited 8 replies Add to Favorites Watch
View HTX_woodworker's profile
HTX_woodworker
22 posts in 255 days
05-24-2018 01:04 AM
Topic tags/keywords: oak planer finishing arts and crafts
Hello all, I’m about to start gluing up a white oak tabletop panel (size: 40”x28”) for a Stickley-inspired lunch table I’m currently working on. I’m trying to determine the best way to clean up and level the desktop after glue-up.
I’ve done a dry run, and the resulting desktop looks good, from what I can tell, with only a few minor height irregularities in a few places. I am still playing around with adjusting the position of the cauls to minimize these irregularities as much as possible. However, I don’t think I’ll be able to eliminate them entirely.
I am attracted to the idea of using a Veritas cabinet scraper to accomplish this task, but was wondering if there are other tools I should be considering? Cheers!
8 replies so far
View bondogaposis's profile
bondogaposis
5151 posts in 2588 days
#1 posted 05-24-2018 01:46 AM
Getting the boards level will be harder than the dry run once you juice it with glue, because of the lubrication affect that glue has. Boards will slip around a lot more. It has been my experience that leveling a table top with only a scraper would take forever. A jack plane will go a long way toward leveling the top in a reasonable amount of time. A scraper will come into play as well to clean up any tear tear out and and minor imperfections. Maybe you are more careful than me and can get a near perfect glue up. The more pieces you have in the table top the more of a problem keeping it level will be.
-- Bondo Gaposis
View TungOil's profile
TungOil
1080 posts in 732 days
#2 posted 05-24-2018 01:51 AM
or take the easy way out and find a local cabinet shop with a wide belt sander willing to run your top through for a few bucks. It will take you longer to make the call and drive there the it will take them to flatten a top that size, and it will be perfect when done.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Loren's profile
10477 posts in 3885 days
#3 posted 05-24-2018 01:52 AM
Alignment dowels can almost eliminate this work.
They take time though. Biscuits are a little
sloppier but quicker.
It’s just elbow grease in any case. A plane will
help get it done faster if you can sense when
to stop planing and start scraping.
View OSU55's profile
OSU55
2026 posts in 2227 days
#4 posted 05-24-2018 08:17 PM
A cabinet scraper is not the right tool to flatten the top. I do use a #80 to remove dried glue. Then planes are used – for that size panel #7, then a smoothing plane. If it is all fairly smooth grain, you are done. If there is tear out, scrapers of various kinds can be used. If you dont have the tools and dont intend to need them again, calling local shops about planing or drum sanding it for you would be the best solution.
View Andybb's profile
Andybb
1611 posts in 841 days
#5 posted 05-24-2018 08:54 PM
- TungOil
+1 It will look and feel quite professional.
-- Andy - Seattle USA
View AlaskaGuy's profile (online now)
AlaskaGuy
4990 posts in 2546 days
#6 posted 05-25-2018 01:17 AM
It s just elbow grease in any case. A plane will
- Loren
Festool domino, quick and no slop. Don’t get too close to the ends where the might be see if you trim the ends off.
AlaskaGuy
#7 posted 05-25-2018 01:18 AM
- TungOil
- Andybb
This is the best if you can. IMHO
View Rich's profile
Rich
4001 posts in 826 days
#8 posted 05-25-2018 01:19 AM
Smart move with the cauls. Even with biscuits or dowels to align the joints, they ensure the result is flat. Taking it to a cabinet shop, if you have one available, for sure will yield a perfect surface.
However, I swear by my 1/2 sheet orbital sander. It’s 40 sq in of flat sanding surface and does the best job of any handheld sander for me. I use it with 80 and 120 grits before moving on to the ROSs for finer grits.
Also, a hand plane will do a great job of initial flattening as well.
