Is a 3.5 amp band saw enough muscle to make 6 inch bandsaw boxes
Forum topic by Of wood and tools posted 05-23-2018 06:37 PM 681 views 0 times favorited 14 replies Add to Favorites Watch
View Of wood and tools's profile
Of wood and tools
6 posts in 238 days
05-23-2018 06:37 PM
Topic tags/keywords: bandsaw bandsaw boxes buying a bandsaw
I am new to band sawing and I’m interested in the wen 10 inch model 3962 bandsaw. I’m going to use it to cut an inch-and-a-half signs for the most part but I would like to try my hand on some 6 inch bandsaw boxes. I’m not sure if a 3 1/2 amp motor has enough power to make such bandsaw boxes.
-- Instagram@ofwoodandtools
14 replies so far
View Steve Peterson's profile
Steve Peterson
395 posts in 3317 days
#1 posted 05-23-2018 07:19 PM
Welcome to LJ, rickanthony,
I suspect that the Wen bandsaw will struggle cutting a 6” tall bandsaw box. I used to have an even smaller 9” Craftsman with a 2.5A motor and it would slow down cutting 1.5” thick 2×4s. It could still cut if you go slowly. I typically used it for small objects like 1/4” plywood and it was great at that.
The Wen has 2 advantages over my saw. The motor is 3.5A (1/3HP) instead of 2.5A (1/4HP). And it has a 2 speed pulley that would give it a 40% mechanical advantage at low speed. Both of these factors combined should give it twice as much power as my saw. This could allow it to cut reasonably well in the 3” range. 6” seems like a stretch. The lack of power might be the reason they added the low speed range.
You could still make 3” bandsaw boxes. :)
-- Steve
View OSU55's profile (online now)
OSU55
2022 posts in 2224 days
#2 posted 05-23-2018 08:47 PM
I have a Craftsman 10” (review here) that can make it’s max ht of cut, 4-5/8”, with the proper blade. I have to take it slow but it will perform well. Not sure it could handle another 1-1/4”, and I havent compared the motor sizes. Im sure if the Wen can do it, it will be slow, and it will be pretty easy to stall it making sharp corner cuts for boxes. I think I would go to a 14” to be sure to have enough umph.
View MrUnix's profile
MrUnix
7105 posts in 2434 days
#3 posted 05-23-2018 08:53 PM
For perspective – here is what the Delta 14” Bandsaw manual states for motor size:
With a sharp blade, it should be fine.
Of wood and tools
6 posts in 238 days
#4 posted 05-24-2018 03:11 AM
I agree with Steve that the Wen bandsaw may not have enough power.
Of wood and tools
6 posts in 238 days
#5 posted 05-24-2018 03:13 AM
to OSU55 point, I almost bought that Craftsman band saw. I didn’t realize it was so close to the RIKON. I thought the Craftsman was a very attractive saw
Of wood and tools
6 posts in 238 days
#6 posted 05-24-2018 03:14 AM
Mr. Unix thanks for your comparison.
I think you off your comments are very useful.
Of wood and tools
6 posts in 238 days
#7 posted 05-24-2018 03:15 AM
I was thinking that with the coupon I could probably get the Harbor Freight 14-inch bandsaw for the same price of the wen what do you guys think about that band saw
View Karda's profile
Karda
1380 posts in 789 days
#8 posted 05-24-2018 06:15 AM
Hi, I have that very band saw, I like it but it is light in the power department. I cut a lot of log wood for wood turning bowl blanks some 4-5 inches thick. This saw will do the work but you cant hurry it
Of wood and tools
6 posts in 238 days
#9 posted 05-24-2018 03:05 PM
Thanks Karda, just to be clear you are talking about the Wen 3962 or the Harbor Freight 14 inch bandsaw which I made a comment about just recently.
View MrRon's profile
MrRon
5261 posts in 3478 days
#10 posted 05-25-2018 12:44 AM
- Of wood and tools
HF bandsaws are clones of saws made by Delta. Like most HF tools, they are OK, and can be tweaked to perform much better. Expect to replace the guides with after market ones, balance the wheels, replace the nuts and bolts and don’t expect long life from the bearings. Other than that, they are not too bad. Any HF tool you buy will be a project in progress.
View DannyW's profile
DannyW
27 posts in 32 days
#11 posted 01-09-2019 09:54 PM
I know this is an old thread but I just ordered this Wen saw and plan to use it for something similar. I am new to woodworking and don’t want to/can’t afford to spend a fortune on something that I haven’t used before. I keep searching CL several times a day for a larger USA made BS but so far have not seen anything worth considering in several months of looking. If I can find anything worthwhile I may go that route but this should get my feet wet.
-- -DannyW
View Steve's profile
Steve
811 posts in 817 days
#12 posted 01-09-2019 10:33 PM
- DannyW
Enjoy Danny. You may want to look into a better blade to get the most out of that Wen.
DannyW
27 posts in 32 days
#13 posted 01-11-2019 12:52 AM
Should be here Monday.
-- -DannyW
View jimintx's profile
jimintx
864 posts in 1819 days
#14 posted 01-11-2019 02:52 AM
I know this is an old thread … I keep searching CL several times a day for a larger USA made BS …
- DannyW
I think you will have a good time using the new Wen when you get it.
That Wen, and a 10” Rikon, Sears, and Jet, all seem to be the same saw. I believe they are made in China.
I’ve seen the 10” Rikon on sale for about $200 a time or two at a local shop, and I am very tempted to add it – but I really don’t have the floor space for two bandsaw machines.
Good luck,
-- Jim, Houston, TX
