Switching between full-kerf and thin-kerf TS blades - Does it throw off your scale?
Forum topic by pintodeluxe posted 06-08-2011 11:44 PM 2521 views 0 times favorited 26 replies Add to Favorites Watch
View pintodeluxe's profile
pintodeluxe
5817 posts in 3052 days
06-08-2011 11:44 PM
Wanting to try the new breed of thin kerf blades for my Jet contractor tablesaw, however I already use a Freud 50 tooth combination blade. I would like to add a Freud 24 tooth thin kerf rip blade to my collection. If I switch back and forth from a full kerf to a thin kerf, do I have to re-adjust the curser on the tablesaw scale each time?
Thanks for any input you may have.
26 replies so far
View Vrtigo1's profile
Vrtigo1
434 posts in 3230 days
#1 posted 06-08-2011 11:48 PM
No, you do not. If you think about it, the side of the blade that faces the fence is always in the same position regardless of blade thickness. If you put the fence to the left of the blade, then you would have to readjust every time you switch blade thicknesses.
pintodeluxe
#2 posted 06-08-2011 11:51 PM
I see you point. Do most blades have the same offset between the blade body kerf and the tooth kerf? I was imagining the offset could be slightly different from one blade to another.
Thanks
pintodeluxe
#3 posted 06-08-2011 11:52 PM
Looking through the Freud catalog could seriously make your head spin.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3525 days
#4 posted 06-08-2011 11:53 PM
In reality, you could have to change the cursor anytime you change blades. The carbide does not always register the same on the blade, even between full kerf blades. Of course it would probably be minimal then.
That said, if the blade mounts on the arbor with the nut toward the fence, it will make a big difference. If the nut is away from the fence, it might not matter—much. There is a difference between left and right tilt saws.
I hope this is not totally confusing. Bottom line—just check it on a scrap any time a blade is changed. I do.
-- http://shepherdtoolandsupply.com/
pintodeluxe
#5 posted 06-08-2011 11:54 PM
Great, thanks for the comment.
Vrtigo1
#6 posted 06-09-2011 12:00 AM
Kent, I did not realize that left and right tilt saws had the nut in different places so thanks for correcting me there. I have a left tilt and my nut is away from the fence. The face of the blade should always be in the same place relative to the fence, as far as how much the teeth protrude I can’t say. I would assume that teeth would protrude the same amount on both thin and full kerf blades, and the difference is that the teeth and the plate of the blade are just wider both wider by the same amount on a full kerf.
View TheDane's profile
TheDane
5575 posts in 3901 days
#7 posted 06-09-2011 12:05 AM
My Jet is left-tilt, and the arbor nut is on the right side of the blade … side as the fence.
Thus, a different blade means a slight difference in the distance between the blade and the fence.
In my case, I adjust the scale every time I change the blade.
—Gerry
View tenontim's profile
tenontim
2131 posts in 3983 days
#8 posted 06-09-2011 12:09 AM
I don’t know if the factory splitters are as thin as a thin kerf blade. I have a home made splitter on my saw, 1/8” thick, and it binds a little when I use my thin kerf blade.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3824 days
#9 posted 06-09-2011 12:10 AM
If the teeth are narrower on the thin kerf saw blade, and result in a smaller cut , then I should imagine that would definitely affect the cut hence the fence setting.The fence settings on my saw are uisually set by bringing the sawblade up till it meets the fence and then set the cursor at zero.Therefore a narrower blade will affect it IMHO I canot see how it wouldn’t.Alistair
View richgreer's profile
richgreer
4541 posts in 3313 days
#10 posted 06-09-2011 12:17 AM
My saw is like Gerry’s and I agree with his point. However, I don’t use the scale on the saw very much. I check distances from the blade to the fence with a metal ruler. For some reason, I just feel more comfortable that I have the distance right that way. I think this is a habit that dates back to the days when my only table saw was a ShopSmith with no index.
SCOTSMAN
#11 posted 06-09-2011 12:20 AM
Yes this was a wiser olden days move, Rich sometimes I do it myself but with my new saw if it doesn’t cut perfectly I am going to tune it til it doesn then cry ilike alil girl f I cant get it perfect .LOL Alistair
View knotscott's profile
knotscott
8178 posts in 3614 days
#12 posted 06-09-2011 12:25 AM
Yes if it’s a left tilt saw, but you can install a shim from a dado set against the flange to compensate for the difference in kerf width. Set the cursor at zero for the full kerf blade, then add the shim for the TK’s….or switch completely to TK’s.
TheDane
#13 posted 06-09-2011 01:41 AM
Before I ditched the stock fence on my saw and installed my Shop Fox, I got into the habit of measuring with the ruler just as Rich does. I still do that … not that I don’t trust the scale on the fence. You know, measure twice, cut once!
—Gerry
View juniorjock's profile
juniorjock
1930 posts in 4004 days
#14 posted 06-09-2011 02:36 AM
The answer to your question is “yes”. If you have a left tilt saw and your rip fence is on the right side of the table.
- JJ
View gfadvm's profile
gfadvm
14940 posts in 2929 days
#15 posted 06-09-2011 05:04 AM
Im with Rich et al,if you are looking for accuracy,use a good steel rule[or calipers].
