Is stropping woodcarving tools common practice?
« back to Woodcarving forum
Forum topic by woodcarverhurr posted 05-23-2018 01:21 PM 1123 views 0 times favorited 16 replies Add to Favorites Watch
View woodcarverhurr's profile
woodcarverhurr
1 post in 148 days
05-23-2018 01:21 PM
Topic tags/keywords: stropping sharpening woodcarving knives honing
Hey everyone,
I just started whittling and know that I need to sharpen it frequently to prevent the edge from getting dull, but I’m trying to find out the different between using a high grit sharpening stone and using stropping with compound.
This post does a great job at explaining HOW to strop with different woodcarving knives and apply the compound
https://www.bestwoodcarvingtools.com/best-leather-strop-for-a-mirror-polish-edge/
but it doesn’t explain what the difference is so I’m confused on what to purchase.
Sharpening stones seem to be slightly more expensive than strops, and both seem to take care of things like blade blemishes and rolled edges. So I’m a little torn between the two.
Any advice?
16 replies so far
View John Smith's profile
John Smith
1368 posts in 307 days
#1 posted 05-23-2018 02:00 PM
I don’t know if it is a “common” practice among carvers today to strop their tools
as the diamond stones are becoming more popular. (so it may be an age/generation thing).
I guess I am too Old School and I have an assortment of leather strops which is
leather glued to plywood with different grades of buffing rouge on each one.
I think this is just another “personal choice” in the wood shop.
-- I started out with nothing in life ~ and still have most of it left.
View Planeman40's profile
Planeman40
1256 posts in 2905 days
#2 posted 05-23-2018 03:00 PM
Let me give you some advice from an old codger who has been at this for 60+ years.
1. I view sharpening as divided into two parts, (1) shaping the edge, (2) sharpening the edge.
2. Shaping the edge is rough work that can be done on a grinder as long as you don’t over heat the edge (it begins to turn blue). Constantly dip it into a jar of water to keep it cool.
3. The actual sharpening begins with a coarse grit (around 200 to 300 grit) You want to refine the grinding, finish any needed small shaping, and remove all of the coarse scratches from the grinding wheel.
4. You now want to move through two or three sharpening stones of increasing fineness until you get to around 600 to 1000 grit. The object is to remove all of the scratches from the preceding stone. I favor diamond “stones” for this. I use the ones from Harbor Freight which work very well. Periodic viewing of the sharpened surface under magnification as you work is very helpful, particularly if you are new at this. Watch your progress and learn.
5. At this point you move to the very finest stone. Personalty, I favor Arkansas stones as they are hard and stay flat unlike water stones which are messy and wear relatively quickly and need periodic flattening.
6. Now its time to check to see if you really have sharpened your edge enough. This is hard to determine for beginners. The best way and the one I use is to use a 2X (two power) magnifying visor. Walmart has one for $13 that is probably as good as the $40 ones. A jeweler’s loupe would work too. Shine a strong light directly on to the sharp edge and view the edge through the magnifier. If you see the edge as a streak of white light, the light is reflecting off the edge. You are not sharp enough. Go back a step or two and work some more on the edge until when you view the edge as above you see NO light! That means the edge is so sharp as to not reflect the light!
7. Now you need to final polish the edge by honing. These hones all use an ultra-fine abrasive like jeweler’s rouge (an abrasive in wax) worked into the surface to do the polishing. Keep “stropping’ the edge like a barber strops a straight razor until you can easily shave the hair off your forearm !!! THAT’s the final test.
A good source of sharpening supplies can be had here: https://www.sharpeningsupplies.com/
Also, take a look at the wood carving gouges and knives I made a short while back: http://lumberjocks.com/Planeman40/projects
View Lazyman's profile (online now)
Lazyman
2521 posts in 1532 days
#3 posted 05-23-2018 03:44 PM
I seem to recall that Mary May uses diamond stones followed by a strop. Her online classes are pretty good for beginners. Here is a link to the free classes, which includes her sharpening techniques and she posts videos on YouTube as well. If you are just starting out these are worth a look.
TheWoodenOyster
1317 posts in 2079 days
#4 posted 05-23-2018 04:56 PM
Short answer – the grand majority of videos, books, articles etc. on carving that I have ever seen do include stropping as a vital part of the sharpening regimen of carving tools.
-- The Wood Is Your Oyster
View Aj2's profile
Aj2
1717 posts in 1942 days
#5 posted 05-23-2018 05:07 PM
I use both as planeman points out stones are for shaping. As in changing the bevel angles on your knives. You will be lucky if a new knife is ready to cut.
Most will need some work.
I strop edges for very fine work just enough to draw out a small wire on the edge.But you have to be careful not to over do it.
Good luck
These are my favorite or best carving knifes they all have different shapes.I used a stone with good light to shape them.
-- Aj
John Smith
#6 posted 05-23-2018 05:25 PM
an assortment of “slips and Stones” is nice to have in your bag also.
the further you advance in the hobby, the more “stuff” you will collect.
and to spill some blood on your workpiece is a Right of Passage.
View Carl10's profile
Carl10
109 posts in 601 days
#7 posted 05-23-2018 06:09 PM
It depends on how good of a finish you want on your work. My dad (when he was alive) started writing a book on sharpening (but never finished). Along the way of his years of carving he would always strop his blades after sharpening. Later he developed and sold the ‘Power Strop’ . It is several ~1/4 leather discs glue together and mounted on a mandrel that you could power with a drill fixed to a bench, etc (some sharpening machines now have these type of wheels attached). I was fortunate enough to absorb a little of his knowledge. What he saw under a microscope after sharpening, but before stropping, were tiny burs still holding onto the new edge. More sharpening would not remove them, but stropping would. Without the stropping you sometimes see the gouges left in the wood from the burs. This would depend on the wood of course, but a stropped edge also makes easier cuts.
Hope this helps.
Carl
View TravisH's profile
TravisH
613 posts in 2079 days
#8 posted 05-23-2018 07:13 PM
I do initial sharpening with stones, sand paper, etc…. once there a loaded strop is used frequently as I carve and rarely go back to more aggressive means unless I drop a knife or hit something hard with it to damage the edge.
Cut quality will tell you when to strop.
Basswood and paulowina about all I have carved however and both carve very easy.
View ClaudeF's profile
ClaudeF
767 posts in 1851 days
#9 posted 05-23-2018 08:03 PM
I do the same as Travis: the only time a stone touches my knives is when I break a tip off, or drop one, or otherwise get a nick in the blade edge. The rest of the time I use a strop every 20-30 minutes when carving. The cheapest, and easily most effective, strop is one made from a flat board such as MDF, with a strip of cereal box cardboard glued to it with rubber cement. The cereal box cardboard has stropping compound rubbed on it. I use the green 0.5 micron chromium oxide on one strop and on another strop I have the Flexcut Gold. The cardboard is very thin so as the knife edge is drawn over it, it does not spring back up as most leather will. When the strop springs back up, it rounds the edge of the blade. The light reflecting from the edge is a good indicator of the sharpness (or lack thereof…). Another is to cut across the end grain of a piece of basswood. The cut surface should be smooth and shiny. Any nick in the edge will appear as a little line along the cut surface.
I also don’t use a stone on my gouges and V tools unless I have a nick in them.
Claude
-- https://www.etsy.com/shop/ClaudesWoodcarving
View TheFridge's profile (online now)
TheFridge
10290 posts in 1630 days
#10 posted 05-24-2018 02:03 PM
Yep
View waho6o9's profile
waho6o9
8420 posts in 2721 days
#11 posted 05-24-2018 02:10 PM
View polaski's profile
polaski
16 posts in 1361 days
#12 posted 05-26-2018 12:19 PM
What everyone said. Stropping is the final dressing on a very sharp carving knife. Some knives made with specific steel (like FlexCut) can be stopped frequently without going to sharpening stones.
-- Jeff Polaski
View rwe2156's profile
rwe2156
3090 posts in 1625 days
#13 posted 05-26-2018 01:52 PM
Chris Pye has the best instructional on sharpening IMO.
View Andre's profile
Andre
2062 posts in 1950 days
#14 posted 05-26-2018 03:59 PM
Not just carving tools but also chisels. I just use a flat piece of hardwood loaded with green compound and give the blades a few strokes every so often.
View Phil32's profile
Phil32
94 posts in 48 days
#15 posted 10-09-2018 04:10 PM
Woodcarverhurr – Like you, I started with whittling with a knife, and soon discovered that my knife blade would get dull. So I would carry a pocket stone. With a little spit and elbow grease I’d get it back to its previous sharpness. But as I got deeper into carving, I found that technique was not good enough. I then added a leather strop to my sharpening routine.
The process has continued to evolve. Now I use an oil stone only if the cutting edge is damaged. I maintain the edges of my tools, mostly gouges now, with green compound on cereal box cardboard.
There are many rituals for sharpening hand tools. Try one. If it doesn’t make your tools “carving sharp.” try another. But go slow. Rushing the process is likely to damage your favorite knife or gouge.
-- Phil Allin - Ventura, CA
