Higher Quality Locking Caster wheels
Forum topic by Russell Barnes posted 05-23-2018 04:12 AM 610 views 0 times favorited 13 replies Add to Favorites Watch
View Russell Barnes's profile
Russell Barnes
21 posts in 242 days
05-23-2018 04:12 AM
Topic tags/keywords: caster wheel locking caster table wheels
Would appreciate advice on locking caster wheels to use on my woodworking tables. The ones I have purchased from Woodcraft are driving me crazy as they keep coming apart on the nylon/plastic outer layer after using for awhile. There has to be a better quality available, that are not made in China. Anyone have experience with this?
-- RBarnes Central Texas
13 replies so far
View JAAune's profile
JAAune
1854 posts in 2554 days
#1 posted 05-23-2018 06:25 AM
Rhombus casters are my favorite. We’ve got around a dozen sets in the shop. Some were purchased new and have lasted over 10 years. Others were bought used from eBay and they work just as well. None have been damaged or broken in any way.
Bright Finish Rhombus Casters
Search for item number 23055T42 .
View Loren's profile
10477 posts in 3885 days
#2 posted 05-23-2018 06:31 AM
The plastic resins in caster tires become brittle
with age. I’ve witnessed caster tires on heavy
machines falling off within months of each other
so I think it has to do with the compounds that
keep the “rubber” pliable reaching its age limit.
I had a Shopfox mobile base with bad casters that
broke after a few years. I replaced the front pair
with spare wheels. The machine is about 700 lbs.
I had a German machine of about 1000 lbs. shed
some tires after over 20 years. A Chinese pallet
jack shed one front tire then the other in quick
succession. I bought it used but it was probably
at least 15 years old when the tires broke off. The
weight of the lifted machine was the straw that
broke the camel’s back, so to speak. The object
that broke them is over 1000 lbs.
View Redoak49's profile
Redoak49
3739 posts in 2226 days
#3 posted 05-23-2018 11:10 AM
Double post.
Redoak49
#4 posted 05-23-2018 11:11 AM
Interesting about the Woodcraft wheels. I have had them for many years and under heavy tools with no problems. My son has had the same problem you have. My surface is fairly flat and smooth. I also have mine inside in a air conditioned room.
Russell Barnes
#5 posted 05-23-2018 12:19 PM
View bondogaposis's profile
bondogaposis
5151 posts in 2588 days
#6 posted 05-23-2018 12:49 PM
I like the Fulton casters that Peachtree sells.
-- Bondo Gaposis
woodbutcherbynight
5825 posts in 2646 days
#7 posted 05-23-2018 01:26 PM
Try these guys out. http://shop.servicecaster.com/solid-polyurethane-wheel-casters-s/2183.htm
I have couple sets on equipment here and at work. 700 lb capacity may seem like overkill, but for $25 each that is only $100 while the 100lb ones are $80. More bang for your buck and a serious step up in quality and expected performance.
Russell Barnes
#8 posted 05-23-2018 01:44 PM
- woodbutcherbynight
Appreciate all the replies. Just emailed service caster to try to find out the country of origin for the 700 pound castors (I try not to buy anything from China if I can help it – quality standards not very high). Are you using the 4” locking swivel castor with brake – solid polyurethane 700 lbs ones?
Russell Barnes
#9 posted 05-23-2018 02:01 PM
Unfortunately, my Powermatic table saw PM2000 has similar style wheels with the orange outer layer on it’s integrated movable castor system. You guessed it, they are also coming apart on the Powermatic just like the ones in the photos above. A little older saw that was made in Taiwan (as opposed to mainland China), but wheels are still poor quality (I have only moved this saw twice and not very far). There has to be a better way…
View RobHannon's profile
RobHannon
221 posts in 768 days
#10 posted 05-23-2018 02:05 PM
Unfortunately, my Powermatic table saw PM2000 has similar style wheels with the orange outer layer on it s integrated movable castor system. You guessed it, they are also coming apart on the Powermatic just like the ones in the photos above. A little older saw that was made in Taiwan (as opposed to mainland China), but wheels are still poor quality (I have only moved this saw twice and not very far). There has to be a better way…
- Russell Barnes
I have a PM2000 that the wheels did that as well. I replaced them with steel casters I picked up at home depot. has worked great for me.
woodbutcherbynight
#11 posted 05-23-2018 02:10 PM
- Russell Barnes
My latest build I used 3 inch 400 lb wheels and casters. They had to fit hardware I already had. Loaded this cabinet up and moved it from outside on rough concrete, around two corners and inside shop. Worked great rolls smooth.
View CaptainKlutz's profile
CaptainKlutz
693 posts in 1731 days
#12 posted 05-23-2018 03:59 PM
- Russell Barnes
2 of those wheels in pic appear oblong, which means they carried some heavy loads for long time; Details?
FWIW – Casters drive me nuts as well. :( AZ heat is tough on any plastic wheel over time.
Failures I see are similar, with separation at the urethane to black plastic interface like the break in pic. They fail fastest when carrying loads near or above weight limits. I have posted about this problem in other threads, but will re-post the only 2 solutions I found:
#1) Do not allow the tool/bench to ALWAYS sit on wheels. Most castors have lower load rating when used in static condition (typically 1/2-2/3 of normal). If the wheels are ONLY engaged and supporting load when moving, plastic hub casters last much longer. Bench Casters are one way to do this, except existing versions have useless 100lb rating and do not work well on heavy leads. This method also prevents damage when ground is not level and single caster ends up carrying extra load.
#2) Use a heavy duty caster. Best are all steel casters, but they lack cushion and can be tough to roll over uneven floors. Intermediate option is casters with a STEEL hub, and much smaller urethane wheel thickness. Cast City calls them ‘Polyurethane with iron center’, and they can be sourced many places, like Grizzly, HF, or BORG. After using a few sets of these for last 5 years, have yet to see a failure? I only use steel hub versions, as I have bent a couple of less expensive aluminum hub versions rolling across concrete seams in garage. The aluminum hub failure was due to a single caster rolling over an ledge/groove, which meant it was carrying load of 3 casters, and exceeded the load rating with a large jolt while be pushed around. Drawback to using this style caster is they cost a lot more than plastic hub versions and are not available below 3.5” diameter.
Sigh – If only some OEM (Fulton, Grizzly, Wood Stock, etc) would read this plea and have the overseas castor factory start producing a 400lb+ rated swiveling bench caster with 4” steel hub wheel and 3” high lift distance. Many of us garage shop woodworkers desperately need them on heavy equipment and rough floors!
Best Luck.
Russell Barnes
#13 posted 05-23-2018 04:32 PM
As I remember the one wheel that really looks very oblong has the orange part also coming loose giving it an oblong look. All of these wheels were bad with the orange part either coming off or already CRACKED, even though some do not look that way in the photo. I returned these to Woodcraft BEFORE they decided they would only allow returns up to 90 days. Funny part was four of these were a set I used on a rolling wooden stand to hold my bench grinder. Bench grinder Not heavy at all, but they did stay in a stationary position.
I am so disgusted with foreign manufacturers, that I am hoping people in America will realize how far we have fallen and start making quality items again. Cannot believe how modern Americans accept this junk.
