How flat is your jointer ?
Forum topic by BANick posted 47 days ago 190 views 0 times favorited 12 replies Add to Favorites
View BANick's profile
BANick
28 posts in 220 days
47 days ago
Topic tags/keywords: question jointer
I tried to joint a couple pieces of cherry on my new jointer over the weekend and for some reason, I just couldn’t get a flat surface. The jointer seemed to cut only the first 15” or so then not make contact with the board for the rest of it. These are the longest pieces I have jointed on this machine, about 3’, so that might be why I didn’t see the problem before. Anyways, grabbed a straightedge and rigged up a base for the dial indicator and I found out that the outfeed table is dished by about 3 or 4 thousandths in the center. And on top of that, the outfeed and infeed tables are not coplanar. When I place both tables at the same level around the cutterhead and place a straightedge from one end to the other, the outfeed is sticking up, i.e. there is a gap between the outfeed table and the straightedge just by the cutterhead of about 9 thousandths.
I understand a few thousandths seem like nothing but the goal of a jointer is to joint a surface flat and if I can’t achieve that, the machine becomes useless. So my question is: Based on your own experience, do you think that these imperfections are too large to be able to joint a board flat or is it ok and I just don’t know what the heck I am doing ? In other words, should I send the machine back or get some tool usage lessons ?
-- Nick, Fremont, CA
View ShipWreck's profile
ShipWreck
40 posts in 85 days
47 days ago
That can be cured with some shim stock.
As far as being dished .003 – .004….........that isnt a big deal IMHO.
View GaryK's profile
GaryK
6986 posts in 321 days
47 days ago
I had to shim my outfeed table to get it flat.
You will need a good straightedge to check it, and fix it.
BANick
47 days ago
ok, sounds like I have to shim the outfeed table in the area close to the cutterhead to make the outfeed end go down. Somehow I’m not looking forward to that..
View Dave Herron's profile
Dave Herron
186 posts in 111 days
47 days ago
Your cut depth may be to small. I set mine at 1/16”. Also, if you outfeed table is not set at the correct height you might see that problem. I’m assuming that when you finished the initial pass that you checked the piece and it was not flat yet?
-- Dave Herron, Boise, ID -- How hard can it be? It's only wood!
GaryK
47 days ago
I had to shim mine because it was sagging. Get a straightedge and a feeler gauge to verify it before you do
anything.
1732 posts in 312 days
47 days ago
Hi Banick;
What size and brand is your jointer.
Just curious, what type of adjustments are on the jointer for setting the beds?
Are they dovetailed key ways, or cammed bushings?
BANick
47 days ago
Lee,
This is a brand new Jet 6” with the long bed, JJ-6CSDX. The tables slide on dovetailed ways.
I spent more time on it this evening and it looks like my straightedge is not that straight.. I also checked the knives and they are not really flush with the outfeed table so before I start shimming it, I will get the knives set properly. That may help.
Thanks all for your comments.
GaryK
47 days ago
You need to get the tables even first.
Once they are level to each other across their entire surface, then you adjust the blades to the outfeed table.
BANick
47 days ago
Gary,
Ok, I will try that, but what I was using as straightedge turned out to be not that straight. I just found an article on FWW.com about jointer tune-up with a cool tip on how to make test bars to check table flatness. I’ll give that a try, see if I still see the gaps.
GaryK
47 days ago
Good luck!
View skeezics's profile
skeezics
39 posts in 52 days
46 days ago
check the knives first. lower the outfeed table a little and see if that doesnt help. for flatness 3-4 thousanths is within specs for this machine I believe. when I set mine up It was good out of the box. I ran a checklist and was happy but it did not cut like I thought it should. after raising and lowering the outfeed table I found the just right spot. make some ajustments and try some scrap…. repeat…. repeat… and repeat till it does right. they can be a little finnickey! good luck and let us know how it works out.
fred
-- hey honey! watch this!
BANick
46 days ago
well, I spent a good chunk of my night in the shop but it was worth it, I think I got it right.
First, I used the FWW article to make a test bar, it’s only 3 aligned points of contact but that was enough to show me that the outfeed is not as bad as I measured last weekend. The end portion is sticking up a little but only by maybe a couple thousandths, so I decided not to shim it. Then, I carefully aligned the knives with the outfeed table using a dial indicator, they are within a thousandth of the table’s edge. The only thing left was to give it a try, and I ended up with nicely jointed surfaces that looked pretty flat. The last test I did was to edge-joint 2 boards of the same length and see if the 2 surfaces would mate properly. I ended up with a very slight gap on the first 5” or so but the rest is completely gap-free. This is good enough for me for now, so much better than what I was getting last weekend. I think the reason for that was probably the knives being out of alignment and a bit of bad technique as well.
Thanks all for your help, I’m a happy man again!
