Miters Greater than 60 degrees on Table Saw
Forum topic by OIF2Vet posted 06-08-2011 04:15 PM 6296 views 0 times favorited 6 replies Add to Favorites Watch
View OIF2Vet's profile
OIF2Vet
12 posts in 2427 days
06-08-2011 04:15 PM
I’m making a four-legged quilt display “ladder” for our newborn’s baby room. I need to cut the top ends of the front legs at an angle greater than my miter gauge will allow me on my TS. I’m leaning toward constructing a taper jig and gradually cut, adjust, cut, adjust until I get to the cut line. However, I wanted to know if there were a more precise way to accomplish the task such as a jig that I can construct out of scrap and use in the futre as well.
any suggestions?
Thanks!
-- Rick P, Grafton, WV
View DLCW's profile
DLCW
530 posts in 2524 days
#1 posted 06-08-2011 06:16 PM
Rick,
Lots of times when I have to cut a piece at an angle greater then what my chopsaw can do I take the following router. Cut a piece of 3/4” plywood so it has an EXACT 90 degree corner. Clamp this to the chopsaw to form a fence that is 90 degrees to the fixed saw fence. Place your workpiece so it aligns along this new “fence” you made. Adjust your chop saw for the angle you want. Picture below.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View Loren's profile
9756 posts in 3518 days
#2 posted 06-08-2011 06:58 PM
You can get aftermarket miter gauges that will go saw far as parallel to
the blade. I had one that came with a saw I no longer own. I could
cut tapers with it.
The simple, cheap way to do it is just make a sled and screw a fence
to it at the angle you want.
View richgreer's profile
richgreer
4541 posts in 2944 days
#3 posted 06-08-2011 09:49 PM
This is a response back to DLCW and his proposal using a chop saw. With the approach you are proposing the miter saw is making something very close to a rip cut. Most miter saw blades are strictly for cross cuts. I have found out the hard way that you really need to change to a combo blade when making a rip cut, or something close to a rip cut, on a miter saw.
View tenontim's profile
tenontim
2131 posts in 3614 days
#4 posted 06-09-2011 04:27 AM
Is the cut short enough that you could use a tenon jig? Stand the leg up in the jig an set your blade for the angle you need.
View DLCW's profile
DLCW
#5 posted 06-09-2011 04:56 AM
Rich, I was going based on what Rick said originally. He needed to cut an angle on the end of a board greater then what his miter gauge would turn. I would never advocate ripping a piece of wood on the chop saw. BAD, BAD, BAD idea. VERY unsafe….....
When faced with this angle problem on many occasions I’ve used the setup I showed in the picture. I just picked a chop saw out of the Sketchup library. I tried to figure out how to angle the blade in the drawing but couldn’t do it. The cutting angle needs to be adjusted so you get the desired angled cut on the END of the board.
If anyone got the impression that I was advocating ripping on the chop saw I am VERY, VERY sorry. Please don’t ever try that type of operation – WRONG tool for the job. That is why I put the text next to the saw that said to set the angle on the saw.
13594 posts in 3211 days
#6 posted 06-09-2011 05:49 AM
another way to cut with the miter saw
is to make a 15 deg. wedge
and turn the saw to 45 deg.
with the wedge against the saw fence
(and sticky tape
or some stop under it
to keep it from sliding)
and the board to it
being careful the work doesn’t ‘walk’
into the saw and jamb
