Diagnosing Half-blind dovetail goofs
Forum topic by Bob Fowkes posted 715 days ago 1258 views 0 times favorited 14 replies Add to Favorites Watch
View Bob Fowkes's profile
Bob Fowkes
34 posts in 797 days
715 days ago
I’m hoping there is a dovetail diagnostician out there who can look at a photo and know exactly what I did wrong. Better still, know what I might do to save it…
I’m getting gaps, especially w/ the smaller (in picture, on the right) tail.
The drawer front is QS white oak, the sides and back are poplar.
This is the first of three drawers, and I’d kinda like to figure out what I did wrong. Worst case, I’d like to goof differently on the next drawer ;-)
Thanks in advance.
-- Bob
14 replies so far
View Julian's profile
Julian
880 posts in 1695 days
#1 posted 715 days ago
looks like your pins are too loose. I like to scribe the wood instead of using a pencil so there is a more accurate line to cut/ chisel to.
-- Julian, Park Forest, IL
View Bertha's profile
Bertha
13111 posts in 862 days
#2 posted 715 days ago
You’ve just got a little slop between your strike marks and your saw kerf. It happens to everyone. If it’s never happened to anyone else here, then….it’s happened to me….many times…to this day! Any real correction at this point will change the dimensions of your piece (although ever so slightly). I saw a very clever idea but I cant remember who did it: they (I think) soaked the wood a bit first, then ball-peen-hammered the gaps, allowing the fibers to expand and fill the gaps. Then plane flush. The post is around here somewhere and it was spectacular. Good job on these; don’t beat yourself up. Switch to a wheel/marking knife, etc. and decide where you’re going to put your kerf. Good luck!
View stevovee's profile
stevovee
12 posts in 725 days
#3 posted 715 days ago
I agree with Julian, go pickup an exacto knife to use for marking instead of pencil lines also i can’t tell from the picture but check to see that all of your saw cuts and chisel cuts are square this is very important if its tapered any it can be tight at the bottom but a gap can show at the top. I started using the veritas saw guide setup and clamping a chisel guide up when i chisel and now you couldn’t even see light through my dovetails they’re so tight
-- -whatever you do keep making
Bertha
#4 posted 715 days ago
And for the record, that tiny little saw-mark into your “keep” portion; that’s my favorite part. It allows me to respect how you executed these difficult joints. Excellent.
Bertha
#5 posted 715 days ago
These are hand-cut fulls in 1 1/8” purpleheart with zero slop using an $18 Lowe’s backsaw, some throwaway Irwin chisels, AND a Titemark wheel and ubersharp marking knife. It can be done; just get some sharper marking devices and go after it.
Bob Fowkes
#6 posted 715 days ago
Thanks, guys. I use a wheel gauge to transfer measurements and a sharp knife to scribe the tails; I trace the marks with pencil ‘cause my basement shop is too dark, or my sight too poor, to pick up the marks. The chisel and saw should fall into line, or that was my hope.
OK, I just checked. the back wall of the half-blind on the right is NOT perfectly straight down. Let me work it w/ the chisel and see what I can get….
-- Bob
Bertha
#7 posted 715 days ago
Strong work, Bob. Make sure you’re kerfing (is that a word?) on the chosen part of your strike line (which you’re clearly doing with appropriate tools). If you mistakenly cut on different sides of the strike line, you’ll be sloppy by a kerf width. Some people “split” the mark, but I’m not that daring. You can always back-bevel the hidden parts; we won’t tell :)
View Bernie's profile
Bernie
381 posts in 1006 days
#8 posted 714 days ago
I understand the comments made and agree with the discussion. I always use a cutting knife to mark my work because a cut is much more accurate then a thick pencil mark.
But I’m seeing a whole different problem here and it could be the result of my failing eyes. They were perfect until I turned 45. That’s when my arms shrunk so I couldn’t read the newspaper. Now, at 60, I need to re-exam my bi-focal every other year and I may be due. Looking at the pictures, I see shadows rather then spaces along the joints. If that’s the case, then your tail cuts are too deep along with the depth of your pins.
Just an observation from an old fart who may need to have his eyes re-examined!
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
Bob Fowkes
#9 posted 714 days ago
Bernie – I know what you mean about the vision going south. It makes a humbling hobby all the more challenging!
-- Bob
4884 posts in 1817 days
#10 posted 714 days ago
There’s a little Jim Krenov trick of paring the sides of the pins
a bit curved so they close up tight but the joint goes together
easily enough.
Read his books if you’re into this hand work stuff.
View Bsmith's profile
Bsmith
257 posts in 839 days
#11 posted 713 days ago
Wow, wish my first ones looks as nice. I don’t know what problem is but the solution is practice, practice, practice. Good work.
-- Bryan
Bob Fowkes
#12 posted 650 days ago
It does take a little practice, each drawer’s dovetails improved a bit as I progressed. A pic of the finished piece:
http://i1100.photobucket.com/albums/g415/bobfowkes/cabinetdrawers.jpg
-- Bob
View fussy's profile
fussy
964 posts in 1220 days
#13 posted 648 days ago
Bob,
They look really good. Back when Nahm was on, he showed closeups of priceless pieces in Hahvard’s collection and the dovetails of some of the finest craftsmen of the day didn’t look any better than yours. Hold your head high, keep at it, and get some better light so you can see your line.
Steve
View Derek Cohen's profile
Derek Cohen
140 posts in 2138 days
#14 posted 645 days ago
Hi Bob
You have to sneak up on the baselines. Baselines are all important for a fit.
Article 1: http://www.inthewoodshop.com/Furniture/Londonhalf-blinddovetaileddrawer.html
Article 2: http://www.inthewoodshop.com/Furniture/DovetailBaselines.html
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
