Arbor Wrench stuck
Forum topic by Lindz posted 05-21-2018 01:43 PM 589 views 0 times favorited 8 replies Add to Favorites Watch
View Lindz's profile
Lindz
1 post in 149 days
05-21-2018 01:43 PM
Topic tags/keywords: table saw arbor nut
After reading the posts about the arbor nut being stuck, I finally got my bade off my table saw. But now the arbor wrench is jammed so tight on there I can’t get it off. Any suggestions???? I’ve tried WD40 and a hammer.
8 replies so far
View John Smith's profile (online now)
John Smith
1357 posts in 305 days
#1 posted 05-21-2018 02:03 PM
heat it with a bottle torch. (the wrench – not the nut).
if your hammer method is not working ~ you need a bigger hammer !!!
WD-40 is not a penetrant – and will not work on two pieces of steel that is only forced together.
heat and coaxing it apart with force is one way.
if you have an identical wrench, sacrifice the stuck wrench and cut it off
with the angle grinder. (the wrench – not the nut).
a piece of pipe, socket, or something that the nut will fit in would provide equal support
around the nut while tapping it out with a hammer.
Last Resort
-- I started out with nothing in life ~ and still have most of it left.
View PatrickIrish's profile
PatrickIrish
127 posts in 2188 days
#2 posted 05-21-2018 04:01 PM
have a torch? Heat it the wrench and bend the mouth open.
View Woodknack's profile
Woodknack
12369 posts in 2522 days
#3 posted 05-21-2018 04:06 PM
Bigger hammer.
MrUnix
6922 posts in 2341 days
#4 posted 05-21-2018 05:47 PM
Where is it stuck… on the arbor? If so, stick the blade and nut back on there so you can apply force in the opposite direction to back it off and break it loose. In the future, just use a wrench on the nut, not the arbor (just use a 2×4).
View bilyo's profile
bilyo
332 posts in 1245 days
#5 posted 05-22-2018 03:41 AM
I’m assuming that it is one of those flat stamped steel wrenches. If so, it is likely that it is a much softer steel than the arbor nut and since it is stuck that tight, it is probably chewed up and deformed anyway. I suggest that you cut it off and buy a new one. Hopefully your arbor nut is OK.
View bbasiaga's profile
bbasiaga
1240 posts in 2137 days
#6 posted 05-22-2018 01:35 PM
Bigger hammer.
- Woodknack
If brute force isn’t working, it’s because you aren’t using enough.
Brian
View Fresch's profile (online now)
Fresch
314 posts in 2063 days
#7 posted 05-22-2018 02:40 PM
Throw it all away and buy a new saw! You know you want one and this one is “broken ”!, see honey!
John Smith
#8 posted 05-22-2018 03:53 PM
well – since Lindz, the O/P hasn’t checked back in, he has either fixed
the issue or broke it beyond repair – who knows. . . . . . .
