router adapter for Montgomery Wards Radial Arm Saw Model TCP 2610E
Forum topic by KTNC posted 05-21-2018 05:16 AM 1080 views 0 times favorited 2 replies Add to Favorites Watch
View KTNC's profile
KTNC
77 posts in 307 days
05-21-2018 05:16 AM
Hello:
I’m looking for a router adapter for my Montgomery Wards Radial Arm Saw Model TCP 2610E.
Part number 84-2613
Do you have one you’d like to sell?
regards, Kerry
2 replies so far
View MrRon's profile
MrRon
4853 posts in 3295 days
#1 posted 05-21-2018 02:48 PM
I’m not familiar with the model number, but Montgomery Ward used to sell a radial arm saw that was made by Magna engineering, the same company that made the Shopsmith 5 in 1 machine. I had the RAS and if it is the same tool; it had variable speed so it could go up to 6400 rpm for router use. I no longer have that saw and not sure it is the same one you have. If it is the same, you might try contacting Shopsmith to see if they still support the RAS.
Correction: It was called the “sawsmith” and made by Yuba Industries which once owned Shopsmith. The saw dates back to the 1960’s.
View KTNC's profile
KTNC
#2 posted 05-22-2018 03:18 AM
Hi MrRon:
That’s not the same saw, but thanks anyway. I’m doing a blog on the restoration if you want to see some pictures of the saw.
http://lumberjocks.com/KTNC/blog/122441
This one has a 20,000 RPM spindle with 15/32 inch diameter 20 threads per inch. It also has a 3450 RPM spindle with 1/2 inch diameter 20 TPI and you can put a standard drill chuck on that one.
regards, Kerry
