How many tpi for beefy dovetails
Forum topic by camin posted 06-07-2011 02:11 AM 1002 views 0 times favorited 5 replies Add to Favorites Watch
View camin's profile
camin
10 posts in 2984 days
06-07-2011 02:11 AM
I have to cut some dovetails into 1 1/2” thick red oak. The dovetails will be 2” deep. Don’t have band saw. Am reasonably proficient with hand saw in cutting dovetails in thinner stock. The pieces are the side rails on workbench I’m building. Will use back saw for job. Can re-file to rip profile on teeth. Any suggestions for how many tips per inch I’ll neesd?
5 replies so far
View RGtools's profile
RGtools
3372 posts in 2560 days
#1 posted 06-07-2011 02:51 AM
I would not stray from 15tpi. But I would recommend a fairly steep rake angle (like 90 or a hair less) to spead things up.
-- Make furniture that lasts as long as the tree - Ryan
9958 posts in 3554 days
#2 posted 06-07-2011 02:58 AM
9-12
I use a bowsaw for large dovetails with a refiled butcher saw blade. I
think it’s 11 TPI but it might be 9 or 10.
Most of the set is filed off on a stone. The saw has so little set it jams
in the kerf unless waxed. That’s the idea; it tracks like a dream.
View Newage Neanderthal's profile
Newage Neanderthal
190 posts in 2456 days
#3 posted 06-07-2011 10:39 AM
I second 9-12. I would also lay the rake back a bit from nearly zero as mentioned, just going to be rough on the teeth and have a hell of a time starting it. I would put the rake at about 10-12 degrees.
-- www.newageneanderthal.blogspot.com . @NANeanderthal on twitter
Newage Neanderthal
#4 posted 06-07-2011 10:19 PM
Sorry about leaving out one important bit in my last post. Meant to say I would put the rake at 10-12 degrees at the toe and move to 4-6 degrees as you move towards the heel.
RGtools
#5 posted 06-08-2011 04:39 AM
Neanderthal trumps me. That makes a hell of a lot of sense.
