Box bottoms
Forum topic by ClayandNancy posted 06-06-2011 10:19 PM 970 views 0 times favorited 3 replies Add to Favorites Watch
View ClayandNancy's profile
ClayandNancy
519 posts in 3014 days
06-06-2011 10:19 PM
I am starting to get into making boxes, I built a box joint jig and will start off with that type of joint. Then will test my skills with some dovetails. But my question is, what are you using for the bottoms, plywood, hardboard, or solid wood? If solid wood, are you gluing up then planning to say a 1/4”?
3 replies so far
View Gene Howe's profile
Gene Howe
10479 posts in 3427 days
#1 posted 06-06-2011 10:30 PM
Depends on the style. Some box bottoms are joined to the sides. In that case, I use solid wood. Sometimes I use a hardwood plywood in grooves in the sides. Other times, I’ve used solid wood. In either case, the bottom panel is not glued and I stay shy of the groove bottoms by about a 32nd.
!/4 is good. I usually plane the solid wood to 3/8 and do a raised panel type bottom. When using ply, the size of the box dictates whether the bottom needs to be 1/2, 1/4 or 1/8.
View rance's profile
rance
4258 posts in 3159 days
#2 posted 06-06-2011 10:50 PM
1/8” baltic birch plywood. No blade change on the TS. Simple & looks good.
View Jim Finn's profile
Jim Finn
2656 posts in 2921 days
#3 posted 06-07-2011 12:30 AM
I resaw and plane or sand solid wood to 1/4” to make my bottoms. Glue in place or trap in a dado.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
