Riving knife or blade guard lock...
Forum topic by lilredweldingrod posted 06-06-2011 10:17 PM 2724 views 0 times favorited 3 replies Add to Favorites Watch
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3304 days
06-06-2011 10:17 PM
Topic tags/keywords: tablesaw safety riving knife locking pin
I just learned something new about my new Grizzly G0690 table saw. I am assuming that other manufacturers use the same locking system or very similar.
The bracket with two screws at the base of the riving knife has a spring loaded pin to lock the riving knife in place. This pin has a round top with two sides ground flat to pop down into a slot. This will turn to the left to hold the pin out for changing from the riving knife to the splitter/blade guard. I never thought to check to see if it seated. I know now. lol If your saw has a similar setup be sure to seat the pin ALL the way in.
It is conceivable that the blade could come in contact with either and create the ultimate kickback. Metal is much more likely to cut than bruise as wood usually does.
3 replies so far
View SnowyRiver's profile
SnowyRiver
51457 posts in 3677 days
#1 posted 06-07-2011 04:50 AM
I dont think I have seen that kind of arrangement, but you have brought up a good point. Thanks for sharing.
-- Wayne - Plymouth MN
View Joe Lyddon's profile
Joe Lyddon
10320 posts in 4249 days
#2 posted 06-07-2011 05:39 AM
I would go for the Riving Knife…
View hawke777's profile
hawke777
12 posts in 3205 days
#3 posted 06-15-2011 06:42 PM
I’ve been noticing pins on products like the new Bosch table saw and the newer Ridgid model for the riving knives. You can crank down the securing bolt, but if the pins aren’t set, the knife isn’t lined up correctly. Always a good thing to check, so thanks for pointing it out.
-- "This is the buffer... you don't want to be puttin' your face in it!" - My 9th grade shop teacher
